Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-21-2011, 12:35 PM   #1
cochino12
It followed me home?
cochino12's Avatar
Trailer brake problem, please help!!!
I friggin hate trailer brakes!!! ok here is my issue. First off I dont have a ohm/voltmeter here so that isnt helping. However, I do have a +12v test light which shows power coming through the trucks trailer plug, power going to each brake, and can hear the brakes humming when I hit the brake or slide the manual brake on the controller. When I use the slide on the controller the +12v light does get brighter but brakes wont engage.
I have adjusted the brakes several times and I'm pretty sure thats not the issue. Just to be positive I tightened them all the way down and the still wont engage with the truck.
What am I missing?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 08-21-2011, 01:16 PM   #2
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Re: Trailer brake problem, please help!!!
Do you have a good ground thru the trailer plug ?
powerdriver 1958 is offline   Reply With Quote
Old 08-21-2011, 01:43 PM   #3
cochino12
cochino12's Avatar
Yep, i even ran a separate ground from the truck to the trailer
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 08-21-2011, 01:48 PM   #4
Axle
Axle's Avatar
How is the ground point for the brakes themselves? Check them for corrosion.
Alex.
Axle is offline   Reply With Quote
Old 08-21-2011, 02:09 PM   #5
cochino12
cochino12's Avatar
Alex.
Cleaned them, still no luck.
The drum does have some grooving where the magnet grabs the drum? Wonder if that would cause issues?
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 08-21-2011, 02:11 PM   #6
powerdriver 1958
Kid's Mechanic
I wonder how much wear may be on the magnets inside the drum , The magnets do wear out
Old 08-21-2011, 02:44 PM   #7
72freak
Rottenwood Garage Member
72freak's Avatar
This is normally the case along with glazed drums. With age the magnets get weak. I just re-did one of my many trailers and took the cheap way out and did not replace or cut the drums after replacing all the backing plates. They grab but wont stop. I am about to break it all down again and cut the drums.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 08-21-2011, 07:40 PM   #8
cochino12
cochino12's Avatar
Sounds like i might need to just buy new drums.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
