08-21-2011, 02:12 PM | #1 |
rear cab mount ?
Just saw these http://*******************/-63-87-ful...hassis-mount-3 and wondering if they will work on my 66 c20. It had the old s brackets with the rubber in the middle before. If they wont work.. any ideas on where to find some is much appreciated.
Build Thread 66 custom cab lwb http://67-72chevytrucks.com/vboard/s...d.php?t=465726 66 fleet lwb- In process 64 k10 10inch lift 38.5's- In process 92k1500 400hp on 38.5-parts truck now 8( |
08-22-2011, 12:28 AM | #2 | |
60-66 Nut
Re: rear cab mount ?
Those won't work. The '67-'72 mounts are slightly different than the '63-'66's.
You can get your original ones rebuilt from Steel Rubber. A former member here, Tony Smith makes repro's for the '63-'66's, but I'm not sure how to get in touch with him. Quote:
08-22-2011, 11:06 AM | #3 |
id rather go with the solid mounts. guess im in for a fab job. oh well
Thanks capt
08-22-2011, 11:27 AM | #4 |
1965 Chevy C10, 2005 4.8L/4l60
there is probably someone on the forum that has these on a parts truck that you could get. put in the WTB and or the parts WTB section
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-22-2011, 11:28 AM | #5 |
Never Ending Projects
Not sure if you are referencing those mounts that you posted or some home grown solid mounts but the ones in the link you posted still use a rubber bushing between the cab and mount. These do not bolt directly to the cab.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
08-28-2011, 01:48 PM | #6 |
Oh no im talking about the c20 custom camper mounts with the rubber that runs vertical. They suck and r expensive to repair. Im looking for the style that has a rubber cab mount like the ones above.
Thanks Clyde, Ill give that a shot.
08-28-2011, 02:58 PM | #7 |
Just an fyi, if you get the c10 rear cab mounts and brackets, they'll bolt right on.....surely someone has an extra set of frame brackets you could pick up....
I discovered this on my truck, which started as a c20 and I robbed some rear cab frame brackets off of a '65 truck bed trailer I picked up....hardest part is getting the rivets off, all the holes are in the same location
Pro Touring 1964 C10-Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=441627 Project '65 Short Step Daily Driver http://67-72chevytrucks.com/vboard/s...d.php?t=661948 |
09-03-2011, 07:48 PM | #8 |
yeah those rivets are definitely well set. Thanks for the info. I'll look around before building a set.
09-03-2011, 09:00 PM | #9 |
I bought a set for my c20 from Tony, they were well made and fit great. He can be found over on Stovebolt.com.
09-03-2011, 09:44 PM | #10 |
OR his new website on facebook 4-5-6 chevy trucks
09-04-2011, 01:58 AM | #11 |
Out of curiosity, what happened to Tony? I've bought a few parts from him and benefited from some of his posts.
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
09-04-2011, 07:51 AM | #12 |
I'm not sure, but I believe banned/suspended sometime within the last year or so?
09-05-2011, 10:01 AM | #13 |
1961 crewcab
here is a set on ebay:http://cgi.ebay.com/ebaymotors/1965-...item2c5eee052d
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
11-26-2011, 02:16 PM | #14 |
But Found Her 25yrs Later!
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
11-26-2011, 05:26 PM | #15 |
i could check my 60 parts burb, they might be good
11-27-2011, 01:32 AM | #16 |
I also bought new rubber mounts from classic parts:
http://www.classicparts.com/prodinfo...141&variation=
