Old 08-21-2011, 02:57 PM   #1
vtwinsport
vtwinsport's Avatar
heater box control valve
Hey all,
Anyone know if someone is making these little plastic end pieces in metal? This is the second time mine has broke and I only found out through summer cleaning of the system.
76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262
http://beerbreadbike.wordpress.com/
vtwinsport is offline   Reply With Quote
Old 08-21-2011, 03:21 PM   #2
tucsonjwt
Re: heater box control valve
Classic Parts has them. Air recirculating valve link rod part. $1.95, so you might as well get several like I did - shipping is more than the part cost.
tucsonjwt is offline   Reply With Quote
Old 08-22-2011, 09:03 AM   #3
vtwinsport
vtwinsport's Avatar
Thanks. I think I'm going to fabricate one, either out of a chunk of aluminum or flast 18 guage steel. I shoudl have pics up by end of the week. I don't want to have to fix this again.
Old 08-22-2011, 10:56 PM   #4
dswancutt
They were still available from GM for $2.25. p/n 3018715
dswancutt is offline   Reply With Quote
Old 08-22-2011, 10:57 PM   #5
vtwinsport
vtwinsport's Avatar
Here's my fabricated replacement. Made out of scrap 18g galvanized steel. Took a 2" x 1.5" square (sort of) and and marked where old plastic piece went.
bent over a tab for the plunger arm to attach to and mimick the old plastic tab. drilled a 1/8 hole. lined up on the vent door, marked with pencil two holes and drilled 2 1/8 holes. Used sheet metal screws (truss heads) (pancakes) about a 1/2" long. Use a small cotter pin to replace the nail chev used. Might write how to on the blog about it for those who want more detail.
Workes great. Just make sure you hold the door closed by the rod above the box to make sure the plate isn't too close to the left and prevent the door from closing (my first attempt).
Old 08-22-2011, 11:01 PM   #6
vtwinsport
vtwinsport's Avatar
But they're plastic right? The plastic ones keep breaking on mine.
Old 08-23-2011, 09:59 AM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
looks awesome
may wana patent that eh!
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 08-24-2011, 08:07 PM   #8
vtwinsport
vtwinsport's Avatar
No hangups with this design. 2 days later and it works just fine.
