Old 04-08-2003, 11:19 PM   #1
Jackal2k9
Jackal2k9's Avatar
Heavy?
What is the wieght of these trucks? gross or something. i cant find it anywheres all my tags are gone this one is a swb stepside, 1970
Jackal2k9 is offline   Reply With Quote
Old 04-09-2003, 12:05 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If you have a small block in it, it'll be tipping the scales between 3700 - 4100 pounds.
Old 04-09-2003, 04:52 AM   #3
Southpa
Southpa's Avatar
The last time I weighed in at the recyclers the truck was 4200 lbs, minus my 200 lbs equals 2 tons on the nose. 1970 GMC longbox w/ stock 350 V-8. Yours should be around 3700 lbs.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 04-09-2003, 06:37 AM   #4
Project1970
14.1 @ 96MPH
Project1970's Avatar
It varies quite a bit...the skinniest I've ever weighed my GMC is at 4150lb with me in it...so 3920lb. 350, 1/2 ton, short/fleet...
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 04-09-2003, 11:51 PM   #5
Longhorn Man
That's about what my GMC short/fleet small block/auto weighs too.
Old 04-10-2003, 12:32 AM   #6
'72 Shorty
I finally got an avatar
'72 Shorty's Avatar
I feel like a lightweight around all you guys. 3800lbs with me in the seat.
-72 C-10 short step (straight line only)
12.922/102.28
-69 C-20 on Propane (DD)
-69 C-10
-56 Mack B-753LS (tow rig)
-94 Chev K2500 Short Ex-Cab
-89 Isuzu Trooper...Kinda
-03 Kawasaki KFX-400
-05 Suzuki DRZ-400S
'72 Shorty is offline   Reply With Quote
Old 04-10-2003, 08:17 PM   #7
Jackal2k9
Jackal2k9's Avatar
i wonder if an aluminum block lt1 wil drop taht very much? heh its probably more right now tho... i have a huge steel plate in the bed. TY though i had no idea at all. im thinkin about puttin sways on it. makin sure i get good stuff for it.
Old 04-10-2003, 08:45 PM   #8
crazy longhorn
Fabricate till you "puke"
4040 on my longhorn, less driver & about a 1/2 tank of gas. She is pretty stripped tho, running 1/2 ton suspension, no heat /ac, alum heads & intake, jazz plastic buckets, steel tilt clip/no inners, no front bumper.....no door glass crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 04-10-2003, 09:04 PM   #9
Jackal2k9
Jackal2k9's Avatar
nice damn truck czyl. btw is anyone interested in a 383 stroker with port/polish heads 1.94/1.50 matched to edelbrock performer intake with a 650 vac sec carb tuned to this motor perfectly. blueprinted, balanced, clearanced bottom end. Has forged aluminum pistons and h-beam rods, Bottom end could probably take a good bit of nitrous fairly easily. But in any effect its extrmely light rotating assembly. just finished break in on it. I have 2 cams and ill put in either one you like. It has a stock cam in it right now. It's a reall stump puller makin 280 horse and 430 ft lbs of tq. I also have a lunati cam 230/230 @.050 (292/292 actual) with .48/.48 lifts. This one would make 400 hp and 410 lbs of tq at 6,100 rpms. It also has a th350 TCI streetfighter build with a stage 2 shift kit and a stock stall converter. I think its one of the steeper 1st gears because its at more rpms at 30mph in first than one with a stock th350 with 3.73 gears and same tires. I got to sell this thing i figure a balanced and blueprinted 383 makin 400hp and a racing trans. is worth atleast 3500 or so. It's all new stuff. I have a lokar floor shift on the trans right now. I'll throw that in if it goes for 3500. im about to list it one EBAY, in the local paper, and taking it to a swap meet this weekend. It may not last through that meet though. 400hp balanced and blueprinted with a spec sheet and a racing trans is hard to come by for 3500.
email if you kow anyone interested please. This things gotta go.
Old 04-10-2003, 09:20 PM   #10
bigjimzlll
bigjimzlll's Avatar
3715 with 10 gals of fuel and 10lbs of N20...
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 04-10-2003, 11:10 PM   #11
68CST327
Psshhh... My C20 weighs 4790. BEAT THAT!
68CST327 is offline   Reply With Quote
Old 04-11-2003, 12:37 AM   #12
Jackal2k9
Jackal2k9's Avatar
thats a fat truck 68 damn pushin 2.5 tons
Old 04-11-2003, 09:21 AM   #13
Longhorn Man
Just wait till I weigh my one ton with the caddy big block. Can you say PIG?
Old 04-11-2003, 10:26 AM   #14
lukecp
Formerly yellow72custom
lukecp's Avatar
Mine weighed about 4040 with me in it. That is a 1/2 ton, lwb, with a 350/350 drivetrain. That puts it at about 3840 empty. These trucks weigh less then almost all new minivans, lol
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 04-11-2003, 10:02 PM   #15
Chevy67Tk
Chevy67Tk's Avatar
When you weight it you might be surprised; I had a mini modified pulling tractor with a 500 Cadillac, not much heavier than a SBC whole lot lighter than a BBC. The tractor ready to run including driver has to weigh in under 1,550 Lbs.
Chevy67Tk is offline   Reply With Quote
Old 04-11-2003, 10:05 PM   #16
Longhorn Man
Oh yeah, i know...it's the one ton truck surrounding it that is a huge pig.
