Old 08-21-2011, 04:22 PM   #1
Gene
Gene's Avatar
Ram horns I.D.
Can anyone identify wether or not I have a pair of matching ram horns? Part numbers are GM 3846559 LH22 and GM 3747038 RH21. I enter these numbers in google and it sends me to corvette sites. Also, why is one tapered where the donut gasket goes and the other is not? Thanks!
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 08-21-2011, 04:36 PM   #2
vectorit
What?
vectorit's Avatar
Re: Ram horns I.D.
The passenger side is flush, because there is a thermostatic flapper valve that goes on first then the doughnut gasket to pipe.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 08-21-2011, 04:39 PM   #3
Ackattack
Ackattack's Avatar
Re: Ram horns I.D.
This just dawned on me: if you remove that flapper valve, and just use a donut gasket, will you have a horrible exhaust leak. I removed the flapper valve when I put my new exhaust on, and its pretty loud.
Ackattack is offline   Reply With Quote
Old 08-21-2011, 04:51 PM   #4
vectorit
What?
vectorit's Avatar
Re: Ram horns I.D.
I suppose one could remove the valve, but then have to chamfer the the inside so that the doughnut gasket could get a proper seal.
In the past, I would just take an old valve and knock out the butterfly. Since a lot of the times the valve gets frozen into position anyways.
Those valves cost about 65 bones too...
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 08-21-2011, 07:10 PM   #5
Gene
Gene's Avatar
Re: Ram horns I.D.
Ok. tried to install these manifolds and the drivers side has a threaded bracket that hits my alternator bracket? Should I switch sides?
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Old 08-21-2011, 07:52 PM   #6
vectorit
What?
vectorit's Avatar
Re: Ram horns I.D.
The earlier style had the alternator mounted to the exhaust manifold on the driver side.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 08-21-2011, 09:39 PM   #7
Gene
Gene's Avatar
Re: Ram horns I.D.
Cool thanks. I'll have to mount mine like that then.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Old 08-22-2011, 03:47 PM   #8
Gene
Gene's Avatar
Re: Ram horns I.D.
Wow, does anyone know if I can buy just a chamfered spacer to take the place of this valve? I hate to try and modify this manifold.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Old 08-22-2011, 09:21 PM   #9
stsalvage
Scrapper 1
stsalvage's Avatar
Re: Ram horns I.D.
I'v seen that Bracket on the 1967--70 trucks But on my 1964--72 We have a Bracket that are plentiful on Ebay and most all parts catalogs that where really simple to use But the 1968--72 trucks went away from the exhaust mounted alternator
stsalvage is offline   Reply With Quote
Old 08-22-2011, 09:25 PM   #10
stsalvage
Scrapper 1
stsalvage's Avatar
Re: Ram horns I.D.
More photos
