08-21-2011, 04:35 PM | #1 |
rear axle swap . 83 firebird ?
i have been offered the rear end set up from an 83 3rd gen firebird, will this be suitable to use on my 51 3100 ? sorry if its a dumb question, but i dont want to get it if its going to be too wide, thanks in advance
www.broadstreetstudio.co.uk |
08-21-2011, 11:08 PM | #2 |
Re: rear axle swap . 83 firebird ?
Error
08-21-2011, 11:10 PM | #3 |
I'm still trying to figure out what my truck has but I was told mine has a Camaro rear end about that vintage but it's too rusted to pull any serial number off. It works great, just the right width and it looks like this.
08-22-2011, 02:49 AM | #4 |
thankyou for the reply ! its hard to find used US parts like this in england so want to be sure before i waste my hard earned !
08-22-2011, 11:10 AM | #5 |
That looks like a Camaro rear end, that block on the side with two holes in it is for the torque arm.
08-22-2011, 11:18 AM | #6 |
weak rear ends
08-22-2011, 01:45 PM | #7 |
Width wise I think it is pretty close. Most likely 60/62 inches flange to flange. Strength wise unless you are building a 400 hp plus engine I don't see an issue. I would pull the rear cover and inspect the gears and the pin that holds the spiders in as quite often that pin gets sloppy in the carrier and the rear end isn't any good. That is an issue with any GM spicer 10 bolt rear end though.
08-22-2011, 01:57 PM | #8 |
As long as your just going to cruise then the 82-92 F-body rear axle will be OK. If you run at the track or you put anything over 200 hp to it harshly then forget it, those rear axles are made of thin GLASS. I worked at the dealers in the 1980's and we replaced a TON of the 7.5 in Trans Ams, this was the L69 (190 hp/305) engine not some super high torque engine.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
08-22-2011, 02:55 PM | #9 |
its going to be a cruiser, so should be ok , i am hopefully putting a 305 or 350 in , thanks for all the advice and replies
08-23-2011, 12:32 AM | #10 | |
Hollister Road Co.
here are some dimensions GM 60.00 1967-1969 Camaro 60.25 1968-1979 Chevy II/Nova 60.50 1984-1995 Corvette 60.50 1964-1967 Chevelle 62.00 1955-1959 Chevy Pickup 62.50 1968-1972 Chevelle 62.50 1970-1981 Camaro/Firebird 61.00 82-92 9 bolt Firebird Ford 61.00 1964-1971 Ford Full Size 61.00 1949-1951 Mercury 61.25 1957-1972 Ford F-100 Pickup 61.25 1960-1964 Ford Full Size 61.25 1971-1973 Mustang 61.25 1967-1973 Torino, Ranchero, Fairlane Mopar 59.20 1962-1970 8 3/4 B-body 60.00 1937-1948 All Mopars 60.70 All 8 3/4 E-body 60.70 All 9 3/4 E-body 62.00 All 8 1/4 B-body 62.00 1971-1974 8 3/4 B-body |
08-23-2011, 12:34 AM | #11 |
Hollister Road Co.
Thats a camaro or firebird rear, How many cover bolts? 9 or 10?
08-23-2011, 12:47 PM | #12 |
It's a 10 bolt cover with 3:42 gears, no posi. and drum brakes.
Works well for my 300hp (330ft/lbs)....so far! Then again it's a 3200lb truck with a light rear end so I can break them free a little bit to easily some times. |
08-23-2011, 12:52 PM | #13 |
i broke the gears in my old S15 with a mild 305. same 7½" gears
