1997 gmc sas and other stuff.
Ok so I finally started on my pickup, actually the sas is almost done. I would have posted pictures awhile ago but I didn't have my computer.
Here it is when I got it. Except for the primer spots, It had a couple of dents that I got fixed. ![]() Then I put a two inch block in it, cranked the torsion bars, and got some different rims and tires really cheap. ![]() Then the work begins.10 bolt out. ![]() ![]() 14 bolt in, and changing gears. I added a leaf in the rear, and put in a five and a half inch block. ![]() IFS crap out. ![]() ![]() We got a sas kit from off road direct. Front spring hanger in. ![]() Rear spring mounts, and springs in. ![]() Dual shock hoops. ![]() Front axle. dana 60. ![]() Then replaced everything on the front axle. ![]() Front axle in and shocks on. ![]() I put a two inch spacer on the rear and a half inch on the front. Which made the rear 72 inches wide, and the front 71 and a half. so the front is only a half inch narrower. ![]() Heres what it looks like now. with 35 inch tall tires, and 16 inch rims. ![]() ![]() I also found a tonneau cover for only 80 dollars, heres the best pic I have of it. ![]() Heres it parked beside my jeep, which also has 35 inch tall tires on it, there about the same height. ![]()
Re: 1997 gmc sas and other stuff.
It looks awesome. Great find on the bed cover.
thanks
KIDHLR
Very Nice
Christopher Johnson Project - Grafted In AKA the "KIDHLR" Conversion - KIDHLR Meets LPG KIDHLR 2.0 Rise of the diesel(a 6.5 powered 6 Door pickup) Romans 11:17-22 "Branches were broken off so that I could be grafted in" |
ok so I got the exhaust done, and some other stuff, ill get pics up some time in the next couple of days.
#7 | |
KIDHLR
Chris
nice work, what kind of other work was involved in the front axle as far as brakes, wheels, steering, trans crossmember work etc.?
I always see guys do SAS conversion but never see what parts they use or need and what they have to fab or mod to make brakes and steering work or wheels.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
#10 | |
I took the ball joint axle out.
![]() heres the kingpin axle ![]() got it in, and I still need to put new lockouts, barings in the pinion, steering stabilizers on, and I think I'm going to put a track bar on also. ![]() ![]() I also put another inch in the rear, here it is ![]() then the tires weren't balanced right so I put my jeeps 35 inch mud tires on it and it drives fine so ill get mine rebalanced and put them on sometime. ![]() ![]() ![]() I also had the exhaust done ![]() ![]() ![]() ![]() and benoit454 heres some stuff I had to do to get things to work. I had to take a notch out of the steering arm so it wouldn't hit the shock mounts. ![]() then I had to flip one of the cross members over so it wouldn't hit the rear drive shaft. |
I also picked up a tahoe for $150 that has paintable bumpers, and the front one has fog lights, and it has inside window parts that I need for my other project.
#13 |
Chris
nice work so it's all basically stock parts? what did your front axle come from?
#14 |
yea its pretty much all stock from some vehicle, the leaf springs are 2.5 inch lift springs from skyjacker for a 73-87 chevy pickup. the axle is from a 91 f350 ford.
#15 |
Chris
awesome and all the steering and brakes is from the same truck and hooked up to yours without haveing to buy anything else?
I can handle buying some of the bracket kits to hang the springs, but when it comes to the brakes and steering etc. I get lost.
#16 |
I bought a new pitman arm(attaches to the steering gearbox), and the high steering arm(the thing I took a notch out of). Then you can buy a drag link, but I just made mine( if your good at making things then you could also, otherwise theirs might work). You can get everything at offroaddirect.com, but if I were you Id only buy the shock hoops and shock mounts that go on the axle, but Id make the spring mounts, because I had to redrill the holes to mount it and you can't put the tow hooks back on with theirs.
#17 |
I put paintable bumpers on.
#18 |
What size lift spring is in the front, 2" or 4"?
#19 |
2.5 inch soft ride springs in the front.
#20 |
Professional Crow Bar Tosser
My god, that truck is gorgeous. And so much work put into it to make it that way.
Will My Beast "Big Nasty": '92 GMC Sierra K1500 Ext. Cab L31 Swap 4x4 Conversion: 2" Body Lift, 3" Skyjacker Suspension Lift, 9.5" 14-Bolt G80 Rear, 3:73 Gears, 350cid L31 Vortec 5700, 4L60-E Overdrive Automatic My Dad's Beast: CUSTOM '97 Chevrolet Silverado K3500 4-Door Mega Cab Project: 10.5" 14-Bolt G80 Rear, 4:10 Gears, 5.7L 350cid SBC Vortec, 4L80-E Overdrive Automatic "I'd rather PUSH my Chevy than DRIVE your Ford!" |
#21 |
Thanks, I still have to put the steering stabilizers on the axle, put my stereo in(and switch my dash at the same time since its cracked), and paint it, then its finished.
#22 |
Good lookin truck man, I'm getting ready to do a sas swap on my roommates 97 Chevy using the Sky Off Road kit.
Professional hot glue and pop cycle stick engineer. 72 K/20 soon to be C/10, 454, Th400, 9” rear. 01 GMC 2500HD 8.1, Allison, daily/towpig gas guzzler. 78 Bahner 19’ jet boat, 460 Furd turd. |
#23 |
#24 |
cool dude, should turn out great.
#25 |
I got the front windows tinted 20% to match the rear.
![]() I also took the tonneau cover off and put in a chest tool box. I liked how the tonneau cover looked, but I couldn't haul anything taller than the bed so it kinda was an inconvenience. ![]() I used two 2 and a half inch aluminum square tubing and put it between the box and the bed on each side then ran two bolts through the box to the bed. ![]() I also put in four tie downs in the bed, one in each rear corner, and one at the front of each wheel well. I padlocked a chain to one, then ran it through my spare tires rim, then padlocked it to the one in the opposite corner. Its only temporary until I make a holder inside the bed.
| Bookmarks |
