08-21-2011, 04:57 PM | #1 |
1964 C10 with 3-speed, 327 engine from 69 Camaro
Hi, I am new to the board. Does anyone know whether a 327 engine from a 1969 Camaro would bolt right up to the 3-speed trans of a 1964 C10 that currently has a 292 engine? Could I use the stock engine mounts from either the 64 C10 or the 69 Camaro?
08-22-2011, 12:39 AM | #2 |
60-66 Nut
Re: 1964 C10 with 3-speed, 327 engine from 69 Camaro
Welcome to the forum
Yes a 327 will bolt right up to the bellhousing that the 292 was bolted to. I don't think the flywheel from the 292 will bolt up correctly to the 327. You will likely need a flywheel from another small block. The motor mount brackets for the 292 are offset, whereas the small block and 230/250 brackets are all the same. If you need a set of original mount brackets that will work with your 327, let me know. The motor mounts from the Camaro will not work in the truck.
08-22-2011, 12:42 AM | #3 |
Senior Enthusiast
Welcome to the forum!
08-22-2011, 02:07 AM | #4 |
Thanks for the help. My son and I actually got the 292 running today, and it runs smooth. He's only 15 and gets his license in April. I may let him run the 292 for now, then throw in the 327 later. You guys are great.
08-22-2011, 02:09 AM | #5 |
Captainfab, where can I get the motor mounts for the 327?
08-22-2011, 02:44 AM | #6 |
Would also happen to know where the fuel filter is located?
08-22-2011, 03:01 AM | #7 | |
ron |
08-22-2011, 09:23 AM | #8 |
1965 Chevy C10, 2005 4.8L/4l60
Motor perches are different for the 292 and everything else, you would need to source some SB or small 6cyl mounts. You could also go with aftermarket perches.
I have a pair of them if your interested.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
