Old 08-21-2011, 05:55 PM   #1
50-MO
50-MO's Avatar
Frame Help
Hey guys looking for some help identifying a frame. I recently purchased a 1950 Chevy AD truck and it is sitting on what I assume is a mid-70's frame. I found a number on top of the passenger side frame rail around the cab mounting area that shows 'C6S198541', is this part of the VIN?
Also on each frame rail there are numbers stamped about mid way on the sides, Driver's side = 363925 76 5 15 76 and Pass Side = 363925 765 18 76. I assume that these may be parts numbers? Truck has Dana 44 in front and Dana 66 in rear with NP203 Transfer Case.
Looking for some further insight so I know the correct parts to purchase to rebuild the suspension on this frame.
50-MO is offline   Reply With Quote
Old 08-21-2011, 06:47 PM   #2
str8axle55
Re: Frame Help
Pics would help, no such animal as a Dana 66, sounds like it should be a 12 bolt from the rest of the running gear. Is it a Blazer frame, what is the wheelbase?
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
Old 08-21-2011, 08:50 PM   #3
50-MO
50-MO's Avatar
Re: Frame Help
[IMG][/IMG]
Old 08-21-2011, 09:00 PM   #4
50-MO
50-MO's Avatar
Re: Frame Help
Tough tosee the chassis all the way in these photos as the boards and bed are still on it. The wheelbase has been shortened to 118" to fit the Chevy AD wheelbase.
Old 08-22-2011, 06:55 PM   #5
russgt
russgt's Avatar
Re: Frame Help
The rear axle is a corp. 14 bolt. You can tell the difference between the blazer and pick up frames by looking at where the rear bumper bolts up, assuming it hasn't been modified.
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 08-22-2011, 09:55 PM   #6
str8axle55
Re: Frame Help
I would guess 73-77 range 3/4 ton pick-up. Better pics would help. It def looks 73+, 8 lug is 3/4 ton , full time 4WD, due to no locking hubs. Should be a 203 t-case if it is full time 4WD, not sure when that ended though. It may be a 76 as your numbers indicate.
84 Chevy K30 CC SRW
Old 08-23-2011, 12:12 AM   #7
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Frame Help
Are the front frame horns, cut or not?
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
