Old 08-21-2011, 07:30 PM   #1
67chevy2wd
67chevy2wd's Avatar
2005 trailblazer a/c?
I have a 2005 trailblazer and the a/c doesn't work at an idle. I checked the pressures and the low side was 45psi and the high side was 175psi. I thought maybe the compressor was bad so I bought a reman and put it on today. I did a half hour vacuum and then tried to charge it. It wouldn't really suck the freon in very well. I got 2lbs in it (takes 2.8lbs) and the compressor started locking up? The pressures were 45psi and 200psi. The low side still won't come down. I am at a loss now and hoping someone else has some advice. I don't want to pay the dealership to fix this but I might have to.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 08-22-2011, 01:10 AM   #2
67chevy2wd
67chevy2wd's Avatar
Re: 2005 trailblazer a/c?
I might have found an answer. After searching the web I found out that gm has a service letter out for 2005 and older TB's. Apparently at idle the engine fan doesn't engage enough to cool the condenser causing the a/c to not work. I feel like a dip $*#! for not thinking about the fan causing this problem in the first place since it all makes sense now. Oh well live and learn I guess. Hope this helps someone else.
'71 GMC 3/4 ton 4x4
Old 08-22-2011, 08:32 AM   #3
donut
donut's Avatar
Thanks! I really haven't had a problem with the '03, but now I'll keep this in mind.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 08-22-2011, 08:48 AM   #4
truckdude239
truckdude239's Avatar
had that problem yesterday int he shop on a benz ml320 low side was 75psi and high side was pegging 520psi it was in a wreck and the fuse for the fan had blown installed a new fuse and evacuated and recharege the ac was good as new
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
