Old 08-21-2011, 11:41 PM   #1
funkytechmonkey
funkytechmonkey's Avatar
Anyone installed VintageAir in their non-factory AC cab?
I havent seen this done so I am curious how this works. Does the Vintage Air kit come with the vents to install? Do you have to cut the wholes in your dash of do they have those vents that just mount under your dash?
Never wrenched a day in my life and now...
Im doing a frame off restoration on a 1968 C10
with a Porterbuilt Dropmember, Acuair E-Level kit,
Boyd Welds Gas tank and mild c-notch.
Click here to view my build
funkytechmonkey is offline   Reply With Quote
Old 08-21-2011, 11:47 PM   #2
flashed
Re: Anyone installed VintageAir in their non-factory AC cab?
Brian, Im going to watch this thread as I want to add air to mine next year maybe but I dont care if the vents are added or not. I would be perfectly happy with under dash vents if they are made that way like the old dealer added A/C from way back.
flashed is offline   Reply With Quote
Old 08-22-2011, 04:56 AM   #3
You can either cut dash and install their in-dash vents or most people use the OEM vents,which obviously need to be cut in,too. I'm not sure if an under dash vent set-up is offered.
Old 08-22-2011, 09:10 AM   #4
eldogg
eldogg's Avatar
I've always cut the dash for OEM vents. The underdash looks to added on for me. Let me know if you have any other questions. I've done a bunch of vintage air installs.
eldogg is offline   Reply With Quote
Old 08-22-2011, 11:30 AM   #5
funkytechmonkey
Eric... I need to ride up and see your place. Id love to see some of the work you guys have done. Are yall up there on the weekends?
Old 08-22-2011, 04:23 PM   #6
Wrenchbender Ret
I used the Vintage -air Gen-2 universal kit. It was quite a chore to put in. I used under dash outlets. I probably should have used the custm kit but my firewall under the hood is clear. It works real good. I just bought the inside kit & used a factory compresser & a salvage yard cond.
Wrenchbender Ret is offline   Reply With Quote
Old 08-22-2011, 04:28 PM   #7
doodah man
doodah man's Avatar
Could you guys post some pictures of these systems installed on your trucks? I'm either gonna get AC soon or a divorce!
1972 C-10 Deluxe
350 V8 - 350TH
We're not the jet set
We're the old Chevrolet set
doodah man is offline   Reply With Quote
Old 08-22-2011, 04:40 PM   #8
webfoot
This fellow did a nice write up with lots of pics.
http://67-72chevytrucks.com/vboard/s...d.php?t=249479
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 08-22-2011, 08:11 PM   #9
funkytechmonkey
Are there any more pics of a Vintage Air install?
How does someone get a really clean install like this one?
Old 08-22-2011, 09:25 PM   #10
extd56
extd56's Avatar
Here are some pictures of the vintage air install in my crew cab with a smooth firewall.
extd56 is offline   Reply With Quote
Old 08-22-2011, 09:29 PM   #11
funkytechmonkey
Looks pretty clean... Are all the hoses run thru the fender?
Old 08-22-2011, 09:35 PM   #12
extd56
extd56's Avatar
Yep, but when I installed the vintage air in the 67 they were ran a little bit different. The orange truck was done before the crew cab, I like the hoses tucked behind the inner fenders.
Old 08-22-2011, 09:43 PM   #13
rob32472
do you guys have any issues with the unit sweating under the dash?
rob32472 is offline   Reply With Quote
Old 08-22-2011, 11:02 PM   #14
extd56
extd56's Avatar
There is a hose that vents the water out the cab.
Old 08-23-2011, 08:31 AM   #15
eldogg
eldogg's Avatar
Most saturdays and every once in a while a sunday. Come on up!
Old 08-23-2011, 08:34 AM   #16
eldogg
eldogg's Avatar
Universal compac kit and custom lines. Piece of cake....
Old 08-23-2011, 11:20 AM   #17
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
ttt
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
