Old 08-22-2011, 12:12 AM   #1
oldspowered67C10
another gauge option
So I got around to messing with my new gauges this weekend. I have VHX dual 5" universal gauges from Dakota Digital. I think its a pretty cool set-up, modern gauges with all they're cool features but with a somewhat retro look. Looks like they use something similar to a modern GM instrument cluster processor so it has 2 information centers that give warnings for things like low fuel, over-temp, low oil pressure in text form on the gauge faces. Has 2 trip meters, adjustable shift light output, high rpm and speed recall, programmable service interval alert and can do some fun stuff like 0-60, 1/4 mile time and speed.
Uses modern 2 and 3 wire senders for oil pressure, water temp and vehicle speed all included in the kit. All the info comes to a remote mounted control box and uses a CAT5 cable to run to the gauges so you only have to disconnect one thing to remove the gauges. I also am using the Dakota Digital fan controller so thats the small box to the right of the gauge controller and the temp sending unit with the single wire on the intake manifold.
Anyhow, heres the pics, tell me what you think.
oldspowered67C10 is offline   Reply With Quote
Old 08-22-2011, 01:20 AM   #2
jugernot
Life, Be In It.....
jugernot's Avatar
Re: another gauge option
Looking Good.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 08-22-2011, 01:51 AM   #3
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
nice and clean ,good job
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 02-12-2013, 11:53 PM   #4
dohyde34
what did you do with the turn signals and generator/oil light?
dohyde34 is offline   Reply With Quote
Old 02-14-2013, 02:48 AM   #5
oldspowered67C10
For the turn signals I found some generic bulb carriers(I think they were replacement parts for VDO gauges)wired them into the harness and put them in the factory holes. The new gauges have turn signal indicators built into them but I didnt like them as much. Since the new gauges have oil pressure and and volt gauges as well as warning messages for low volts/oil pressure the factory lights are now inoperable(just left the bulbs out).
