Old 08-22-2011, 04:13 AM   #1
chillware
Any tips on how to replace the front fender braces?
Looks like I'm going to need to replace both of my front fender braces, the bottom bolt hole is completely stripped out on one and the other was BADLY drilled out and is now an oval bolt hole.
Anyone have any tips on getting these out? they look like the fender is is just folded over them, how should I go about getting them out?
Or is there an easier way to fix these bolt holes?
Thanks!!
My build thread: '66 Chevy
chillware is offline   Reply With Quote
Old 08-22-2011, 06:23 AM   #2
blackedoutharley
Re: Any tips on how to replace the front fender braces?
Weld them up and then drill and tap maybe? Or Helicoil?
blackedoutharley is offline   Reply With Quote
Old 08-22-2011, 06:37 AM   #3
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
drill an over size hole stick a new bolt in the hole and weld it up done!!!
gostranger is offline   Reply With Quote
Old 08-22-2011, 06:38 AM   #4
PGSigns
PGSigns's Avatar
What I would do with the one in the picture is cut out about a 1 inch square and then make a replacement plate 1 1/8" with the hole drilled in it and a nut welded on the back side. Then weld that to the fender brace and dress it up. Quick and easy fix. Should work on both fenders.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-22-2011, 11:17 PM   #5
Captainfab
60-66 Nut
X2
Originally Posted by pgsigns View Post
what i would do with the one in the picture is cut out about a 1 inch square and then make a replacement plate 1 1/8" with the hole drilled in it and a nut welded on the back side. Then weld that to the fender brace and dress it up. Quick and easy fix. Should work on both fenders.
Jimmy
Old 08-23-2011, 11:57 AM   #6
chillware
alright, I'm gonna cut 'n weld I'll post pics
What was the original bolt size? I'm thinking it was 3/8 Fine Thread?
Thanks!
Old 08-23-2011, 11:52 PM   #7
Captainfab
60-66 Nut
Yes, I believe they are 3/8"-24
Thanks!
Old 08-24-2011, 01:16 AM   #8
chillware
Starting cutting the first one out tonite, got late. Will weld in tomorrow
I ran in to a bit of thin / rusted out metal while cleaning up the edges, you see in one of the pics below.. i cut it back, hopefully enough to not thin to still blow some holes w/ the welder..
Old 08-24-2011, 01:17 AM   #9
chillware
last few for today
Old 08-24-2011, 01:22 AM   #10
chillware
If I cold figure an easy way to get the braces out, i would still do it.. lots of rust behind them
http://www.dreamershotrods.com/front...dgmctruck.aspx
Old 08-24-2011, 04:45 PM   #11
forestb
forestb's Avatar
X2 on his question only mine are rusted out and there are no more holes left. I was wondering if there is an easy way to replace them. The fenders themselves are not rusted just the braces. The PO's solution was to weld the bottom of the fender to the cab.
forestb is offline   Reply With Quote
Old 08-24-2011, 05:19 PM   #12
SFTorange
SFTorange's Avatar
My rear braces were completely rusted through. I had them replaced, and it didn't seem too difficult. It looks like you just have to drill out some spot welds and bend back the fender where it is pinched around the old brace. To install the new one, re-spot weld, and and re-bend the fender around the new brace. I made sure to drill out the drain hole to allow water to flush dirt and grime out from behind my new brace.
SFTorange is offline   Reply With Quote
Old 08-24-2011, 06:02 PM   #13
XtechX
XtechX's Avatar
This trick works great for replacing stripped threads.. Go to the hardware store and buy some threaded T nuts ( I think thats what they're called). drill out the old threads and put them in the hole and weld into place. You now have perfect new threads. But before you can put them in you will need to grind the little teeth off the back of them so they will fit in the hole flat. The teeth are so you could tap them into wood with a hammer I think. This method works awsome and is real cheap.
Opportunity usually comes disguised....As hard work!!!
XtechX is offline   Reply With Quote
Old 08-24-2011, 06:38 PM   #14
chillware
Interesting I may try pulling out and see what happens..
Old 08-24-2011, 06:55 PM   #15
chad64chevy
chad64chevy's Avatar
i dont know if you have a replacement fender brace to look at but im still trying to figure out how i was gonna do my braces! there is a few spot welds and if you look at the top of the fender brace there is another smaller brace with weatherstripping attached its tacked to it and then you can see how it will all go together! i have my fender patches to do and was thinking of cutting the fender patch then go up another 4-6in and cut the brace then weld in the new brace and weld in the fender patch
chad64chevy is offline   Reply With Quote
Old 08-24-2011, 08:04 PM   #16
chillware
if you go that route take some pics, i'd like to see how it comes out.
