Old 08-22-2011, 10:43 AM   #1
puller
2wd cab on 4wd frame questions.
I just bought a 2wd cab for my 1970 c20 4x4 project. I am also going to run big block and have already moved engine and drive line ahead 2 inches. Also have already bought 3 inch body lift from LMC truck. Has anyone mounted 2wd low hump cab with body lift on 4wd before? Do you think I can just leave and cut holes for transfer case shifter?
puller is offline   Reply With Quote
Old 08-22-2011, 11:05 AM   #2
Gene
Gene's Avatar
Re: 2wd cab on 4wd frame questions.
I believe the high hump is for clearance of the transfer case, I would try it. While mine was at the body shop we cut the hole out and there was plenty of room for case clearance. If it wont clear then cut it out.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 08-23-2011, 09:17 AM   #3
puller
Thanks Gene, Do you know if humps are interchangable? I still have my 4x4 cab.
Old 08-23-2011, 05:58 PM   #4
Gene
Gene's Avatar
Yes, just cut out your old one and bolt in your new one. Thats what I did, just go by the outline of your old floor.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Old 08-24-2011, 06:00 PM   #5
bigblocksean
I just put a 2wd cab onto my 72 3/4 ton frame and it clears fine with the low hump. If your running an automatic it clears just fine.
bigblocksean is offline   Reply With Quote
Old 08-24-2011, 06:20 PM   #6
Gene
Gene's Avatar
Thats what I was thinking, but I already had the high hump bought and didnt want my shifter boot to look goofy.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
