6" lift and 37x14.50's
heres a pic of my truck just after the lift went in
1986 Chevy Wrangler 4x4 305/700r4 6" lift 37x14.50x15 |
Re: 6" lift and 37x14.50's
Looks great! Are you using blocks or springs (or a combination)?
![]() 305 ci | TH350 | NP208 | 60k miles |
4" block with an add-a-leaf in the rear....although i need to add another leaf in the back to make it level
![]() Join Date: May 2009
Looks great, that other leaf should make it perfect.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD 84 Chevy K30 CC SRW 55 Chevy 210 2dr post |
how does that 305 push those 37's?
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck ![]() My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
Cool
Bruce 73 Stepside, 74 Blazer, 75 1 Ton, 66 Barracuda and a 05 Electraglide DD http://i56.photobucket.com/albums/g1...Rusti192-1.jpg |
BAD BOW-Silverado XST
Did you the K10 destroyed video? Firm up the frame and suspension!!
#8 | |
Junior Member
I really wouldnt take that video to heart... that truck looked like a huge pile that has been driven hard and put up wet. With the huge meatballs he had on there which I am sure it had big axles and big gears... it was a recipe for destruction... especially if it was on a 1/2 ton unmodified frame. |
sorry haven't been on here for a while.....the 305 isn't too bad....the 6.5 is going to be alot better when it gets swapped in.....
#10 | |
ya a shackle flip is in the works
1986 Chevy Wrangler 4x4 305/700r4 6" lift 37x14.50x15 Last edited by dieseltech; 08-26-2011 at 10:40 PM. |
haha just watched the k10 destroyed video.....bit extreme i think....
#13 |
Looks good!
I just put 6 inch front springs in because the 4 inch ones I got were junk. Still have just the 4 inch blocks in the rear, which already has add-a-leafs and a big 1 ton spring pack. It sits pretty decent, not perfectly level but not a west coast lean either. I'm hoping the front settles in a bit and levels it out. I planned on putting military 37s on it but I've scrapped that idea. Too much work changing the dually hubs and rear axles around to get them to fit. So I'm stuck with little weenie tires. Another reason I don't want to raise the rear any more to even it with the front, the tires are already small looking.
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop. |
#14 | |
#15 |
I think the tires look perfect under it but I hate lifted trucks where the back sits lower its like a disease but that's just me, but yours doesn't sit bad at all
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
#16 |
Well militarys are cheap. But they would need to fit on 6 or 6.5 inch rims. I dont think 12.50s would be too safe on a 6 inch rim. I've been wanting to get 9.00x16s but not had any luck finding any. So I think I'm just going to stick with 235/85s and try to live wih the truck like that. I always want bigger tires, but really the only way to do it would be to switch it back to a four wheeler, which would be costly and pretty permanent, plus it would ruin the whole idea of the truck, which is to have the dual rear wheels tucked under the fleetside bed.
#17 |
still needs a leaf in the back though, but ya i do agree with you on the rear being lower than the front
#18 | |
