Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 08-22-2011, 01:09 PM   #1
1968vetL-71
Junior Member
1968vetL-71's Avatar
73-87 GM Dana 60/14 bolt, 12v cummins and other stuff
Matching set GM - Dana 60/14 bolt srw
D60- 4.56's, posi
14 bolt- 4.56's, Detroit locker ( removed but still in box ), disc brakes (weld on calipers), needs new brake lines. Bought both axles from a buddy who had them under a 73-91 suburban. He spent alot of money having new gears and the posi and locker set up in these. He said less than 2k miles. and from the looks of the disc brakes set up, the pads look new. Just very dirty from sitting under his rig. Just need cleaned up, painted and installed. $1600.00
Also have your next 73-91 crew cab power plant!!
94' 12 valve cummins with the desireable P-pump, only 151k, virgin motor never tampered with, has automatic bellhousing and flexplate still bolted on engine. Also comes with starter, alternator and engine fan. $2300.00
Also have 14 bolt semi-float, 3.73, gov-lock, 6 lug rear end. $300.00
69-72 8" Superlift springs front and rear, new bushings still in pkg's. $500.00
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 09-14-2011, 09:32 PM   #2
mlb 62 gmc
Re: 73-87 GM Dana 60/14 bolt, 12v cummins and other stuff
It appears you say the detroit locker is removed from the axle, would you sell it separately, and if so how much?
mlb 62 gmc is offline   Reply With Quote
Old 09-16-2011, 06:49 AM   #3
1968vetL-71
Junior Member
Its all been sold but the lift which i've decided too keep. Thanks.
