Old 08-22-2011, 06:43 PM   #1
biohazardbill
Bagged trucks and swaybars
I did some searching and found what to do for the front, do any of you also run a sway bar in the rear?
biohazardbill is offline   Reply With Quote
Old 08-22-2011, 07:51 PM   #2
Frizzle Fry
Frizzle Fry's Avatar
Re: Bagged trucks and swaybars
I ran a camaro rear bar for a while. Now switching to hotchkis because I've done a step notch.
Frizzle Fry is offline   Reply With Quote
Old 08-24-2011, 12:13 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
It kind of depends on the configuration of your suspension and available space. This is the type of kit currently available for a factory-type coil spring rear suspension. http://www.classicperform.com/Store/...uck/CP7401.htm
I lowered my truck quite a bit and run a rear gas tank, so room is kind of a premium in my application. As a result, I fabricated a splined torsion-type sway bar assembly that goes through the frame.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-24-2011, 05:14 PM   #4
Shooters_7
Do you have the info for the rear sway bar set up that you constructed in the picture? How does it work for you?
Shooters_7 is offline   Reply With Quote
Old 08-24-2011, 05:35 PM   #5
vin63
vin63's Avatar
It was a left over splined torsion-type sway bar used for sprint cars, etc. It's a solid 1-inch x 42 inch 36 spline unit. The arms are 15 inch. It works really well for my application, but if I used my truck to haul more than a couple hundred pounds or tow regularly, I would go for at least a 1.25-inch, or larger, bar.
Old 08-25-2011, 12:17 AM   #6
shrunken66stroker
shrunken66stroker's Avatar
Anyone else have a rear sway set up to post?
shrunken66stroker is offline   Reply With Quote
Old 08-25-2011, 12:47 AM   #7
Slammed50
I just got the bell tech sway bar for the 73-87 C10 and am adapting it to work with my bag set up. It's a nice unit with all brand new poly urethane mounts and grade 8 hardware, Ill check to see what size it is for you.
Check out my build thread for my '63:
http://67-72chevytrucks.com/vboard/s...49#post4806049
Slammed50 is offline   Reply With Quote
