Wheel hits Tie Rod?
I just finished installing totally new everything except for the A arms and center link on my front end. I went to pop the wheels on so that I could set everything correctly. Well, the wheels hit the tie rod. I believe they are 15" Centerlines (I'll double check in just a bit). These are the wheels that were on the truck when I bought it. Maybe it rubbed then and I just had forgotten, as I quickly put 20's on it. I have since sold the 20s, and was doing to use the centerline for rollers until I was closer to completion to order the wheels I want.
Well as is, I can put the dang thing back on the ground. Did I mess something up, or are the wheels just too small? There is almost exactly an inch between the back face of the disc rotor and the edge of the knuckle/Tie rod end. 1972 Frame, and steering, with discs. Any tips/input?
www.tomthetruck.blogspot.com <-- Aka build thread. |
Re: Wheel hits Tie Rod?
when you say everything, did you change spindles?
Sorry, spindles are the same as before. Essentially moving parts. New Tie Rods, new pittman arm, new shafts in the a-arms, etc.
Not that it matters but i have the ECE 2/4 that has been on there since I bought it. I should also note, I tried popping on some spacers I had laying around 1/2" I believe. Still would rub with those on there. Wheels are 15", just checked
www.tomthetruck.blogspot.com <-- Aka build thread. Last edited by Tmwoodall; 08-22-2011 at 07:26 PM. Reason: Update about wheels |
