Cab differences
Ok, I may have found a cab,maybe free, it's a 76 cab and appears to be cancer free. Are the cabs the same as the 80's cabs. I'm told the difference is in the front clip. I plan to remove everything from mine and reinstall on the 76 cab. At least that way I didn't waste the money fixing the driver door like I did fixing the floors
2024 Silverado Z71 PPV 1972 Chevy Monte Carlo 2018 Buick Enclave (Wifes) |
Re: Cab differences
On the 73-80 trucks the hood hinges went from a 1 pc to a 2 pc on the 81-87, so the hinge on the cowl folds away into the upper cowl. I have cut those sections out and welded them into a mid 73-80 model cab before. It can be done it's just a little more work. Rust free cabs are hard to find so it may be worth it. The doors and all interior parts can inerchange w/ little to no mods.
Re: Cab differences
Also, the wiper posts are longer on the 81 up cabs to clear the cowl panel. They are interchangable, but you may need to drill a couple holes for the screws.
70 stepside 76 blazer 86 Sierra Classic 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
Re: Cab differences
Would my hood bolt to the old hinges . I can keep them greased to prevent the hood from bending
Laid back freak
Re: Cab differences
Here are some pics from a 85 cab i made to back to 73-80 specs
Welded up the holes for the cowl panel ![]() Corners were taken from another cab and welded up to fit ![]() Even took the metal dash out from a 76 cab and changed it over cause 84 and up cabs had the wiper switch on the column and this truck has it on the dash,plus this truck originally didnt have a/c and the cab i got had a/c i went back to the original roots and fixed all that. ![]() ![]() ![]() ![]() thanks pat p.s. i know i went a little overboard but its not a everyday driver.
1980 chevy c10 step side restomod, ![]() 1970 cougar convertible 1 OF 24 ever built: 2014 Hyundai Tucson limited (daily driver). |
Re: Cab differences
Thats pretty cool, wanna come to Texas and do mine (lol)
Will my hood fir the old hinges ?????
Re: Cab differences
The seat belt mounts changed a couple times over the years . i know they changed in 78 to a different style , position , and angle . Might look at that first but the overall cab is the same from 73-80 and 81-87.
Frank
Born and proudly residing in a Red State ! |
Re: Cab differences
Done it a couple of times, "80stepsideguy" pretty much covered it all, Ron
Re: Cab differences
Well found a rust free 86 cab, going to pick it up tomorrow, should nt have a problem at all with anything then right
Laid back freak
Re: Cab differences
You should be good, just keep the old cab for parts if you plan on doing the coversion i did.I will say it isnt for the beginner but if you take your time itll come out great.Just be patient..
thanks pat
| Bookmarks |
