Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 08-23-2011, 12:06 AM   #1
thebacon
Frame Protection (POR15 Vs...)
Hey
I'm just about to paint my frame and want to have it well protected for quite a few years. :P
POR15 seems like a good choice, and better than the other thing I was looking at, a producted called "Corroseal".
My thoughts were to use POR15 for the Frame, Engine Compartment, and the inside of the panels, Along with the floor of the cab (both inside and out).
Then corroseal on the outside bodywork.
POR15 seems like it ends up a bit thicker so would be good/fine for the underside, and offer more protection to those places than corroseal would(I'm afraid that it'll chip easier). Whereas corroseal on the visible areas wouldn't build up the body but still offer protection.
Anybody else thought about this, Used either or both products, will they react to each other somehow?
thebacon is offline   Reply With Quote
Old 08-23-2011, 12:25 AM   #2
brap999
brap999's Avatar
Re: Frame Protection (POR15 Vs...)
I had my '72 GTO sand blasted at a shop, and then they did the entire frame with gloss black powder coating. It looks great, it was relatively inexpensive.
I have heard of many complaints from people using POR15 that it ends up cracking over time.
Others have also mentioned something called Zero Rust. But I have no experience with it.
1963 Chevrolet C10 Stepside
1972 Pontiac GTO
1998 Dodge Viper GTS
1999 Jeep Cherokee XJ
2018 Chevy Camaro ZL1-1LE
It's never too early to beef up my obituary
brap999 is offline   Reply With Quote
Old 08-23-2011, 08:42 AM   #3
Slammed50
I personally like POR-15 on frames especially if you plan on lowering your truck. Powdercoating is nice but once it's scratched there is no touching it up with out stripping it and starting over. I just used eastwoods chassis black on my '63 frame, looks nice and sprayed out evenly but haven't put any road time on it yet. I would recommend the POR-15 in a satin finish and spraying it is a must for nice results. Cover everything up as well, the over spray gets everywhere. Good luck.
Check out my build thread for my '63:
http://67-72chevytrucks.com/vboard/s...49#post4806049
Slammed50 is offline   Reply With Quote
Old 08-23-2011, 08:43 AM   #4
Slammed50
You can see the Eastwood finish on some parts I sprayed in my build thread BTW.
Old 08-23-2011, 11:03 AM   #5
biohazardbill
I used a satin "Chassis Saver" sprayed it on, looks good, seems pretty durable.
biohazardbill is offline   Reply With Quote
Old 08-23-2011, 11:54 AM   #6
thebacon
Powder coating sounds like it'd be nice but cost compared do POR15 or anything else would be quite a bit higher?
Whats everybody using on the underside of fenders? Just paint or some protective coating too?
Old 08-23-2011, 01:15 PM   #7
NONHOG
NONHOG's Avatar
I would use DP90 on a frame then top coat it. In fact you may decide to not topcoat it? I didn't on a frame I did years back. It'll last probably longer than you'll own it. (IMO) I've used the spray on bedliner on the roadside of inner fenders, after proper painting(DP90 again is what I used). Not sure its the best coating but I like the idea of less noise from gravel and such. I'm sure its better than ordinary paint. I used duplicolor from a can. Not as good LineX but that could be done of course also.
thebacon, love the name!
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 08-25-2011, 12:37 AM   #8
Handfull 54
Handfull 54's Avatar
I used POR 15 with a brush on my frame. It seems to be self leveling as I did not see any brush marks. I prayed on their Phosporous adhesive spray first and then painted over it. It's a poor mans powder coat as far as I'm concerned. It has held up well against rock chips too. As far as the inside of the fenders, I used some undercoating from a spray can and that too is holding up. Just my experience.
Handfull 54 is offline   Reply With Quote
