08-23-2011, 11:14 AM | #1 |
What Else Do I Need For This Upgrade?
I am about to install my new Booster Brake System that I bought from a Board Member .
First Picture is of all the new parts I bought . Second Picture is what I have now that I am taking out an replacing with the New . Any advise on how to go about this is appreciated and/or parts I need would help me from running back and forth to town which is some 20 miles .. I know I need a boot for the firewall ,,but can I use the one I have that is in the firewall now or do I need to get a Specific one for the booster set . How about the rubber hose length and the fitting for it ? things like that will help me get the things I need ..
When you learn a thing a day you store up smart. Last edited by GOPAPA; 08-23-2011 at 12:41 PM. |
08-23-2011, 07:12 PM | #2 |
Re: What Else Do I Need For This Upgrade?
ttt
When you learn a thing a day you store up smart. |
08-23-2011, 07:25 PM | #3 |
Looks to me like the rod that goes in the front of the booster is not there. It is what actually compresses the master. It may be what it zip tied to the rod at the back of the booster. Hopefully someone else will chime in. You may need the wire extension for the wire that goes to the proportioning valve.
08-23-2011, 07:34 PM | #4 |
I took my entire brake system apart a few months ago and it looks like you have everything you need except the vacuum hose. Make sure you bench bleed the master cylinder before you mount it.
Posted via Mobile Device |
08-23-2011, 08:54 PM | #5 |
yep looks like you have everything. dont forget to bleed the m/c, and the rest of the system. I had trouble bleeding mine after switching to power. it was the brake pedal to rod angle or ratio. Will worry about that if you cant get the system to bleed.
08-23-2011, 09:15 PM | #6 |
You will need the rubber boot for power booster in the fire wall. The manual brake part will not fit.
The rod from the booster to the MC is not in the picture. Do you still have drum brakes? Drum brakes need to have residual valves. If the MC is for drum/drum, the residual valves should be in the outlets. If the MC is a disc/disc, you will need in-line valves for the drum brakes (10 lb.). The vac hose must BE VACUUM hose. Regular hose can suck flat and disable the booster.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
08-23-2011, 10:07 PM | #7 | ||||
So, I do need a rubber boot that is made for a booster only and I cannot use the one in my truck now without a booster? Is this the rod you are talking about? thx for your advice..
08-23-2011, 11:49 PM | #8 |
That rod is a little different than mine but so it the booster. Mine also has a rubber washer looking seal that went on the rod. If that was ordered as a kit I bet that rod is the right one. Hopefully someone else will chime in to confirm.
One other thing, Some of those masters have fittings on both side so you can route the brake lines to the left or right of the master. If yours is that way there will more than likely be plugs in the side that is closest to the motor. Be sure to check that those plugs are tight. Mine were not. |
08-24-2011, 05:28 AM | #9 |
yea thats the rod. ERASER is right there is another boot you will need. its $8 at classic parts.
08-24-2011, 12:12 PM | #10 |
Ah, missed the rod.
mrhino has the right picture. I would still examine the rear brake port for a residual valve. As President Reagan used to say, "Trust, but varify."
08-24-2011, 01:36 PM | #11 |
I knew I needed a boot and found out by posting that I needed a boot specific for a power booster set up..and I found on page 78 of classic catalog a boot ,,but it is not the one you have shown in the picture you posted, any reason why the difference?
08-24-2011, 03:53 PM | #12 |
As far as the boot....I thinks Wes at Classic Heartbeat will be getting those in soon. He announced this, I think, last month. Give him a call...good parts!
-John |
08-24-2011, 06:16 PM | #13 | |
I orderd one from Classic Parts today.. thx though all the same. ..
09-02-2011, 08:38 AM | #14 |
[quote=GOPAPA;4860634]I am about to install my new Booster Brake
{{{{Where exactly does the black washer the size of a silver dollar fit into place that is in the center of my picture of parts?? My plan is to install all this the day after Labor Day.. }}}
09-02-2011, 09:09 AM | #15 |
I believe that is the seal that goes in the front of the booster, behind the master and the small rod goes through the middle of it.
09-02-2011, 10:12 AM | #16 |
thx I bet you are correct..
