Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-23-2011, 05:57 PM   #1
Surfdaddy
Surfdaddy's Avatar
Generator light
since I got my truck running The gen light has been on, kind of dim and brighter as the RPM's go up. While driving the signal works pretty fas and slows as the rpm's solw. I measured the voltage and it was 13.5 volts at idle. I figured the regulator was going bad so I changed it and now the voltage is now 12.6 wich seem low. The light is still on but stays the same reguardless of RPM, (on and pretty dim). Everything seems ok and it's been so long since I messed with a generator, but, I think I remember that you may have been abe to adjust the voltage by adjusting screw on top of the field coil. Is my memory right or is is just wishful thinking. I thought the regulator was bad and the light would go out but now I'm kind of puzzled.
1961 GMC. Start date 1/20/2011
Past projects:
1958 Fleetliner 14ft Runabout
1966 Caprice 2dr
1970 VW Squareback
Surfdaddy is offline   Reply With Quote
