08-23-2011, 06:39 PM | #1 |
help help help.. track bar
i have a 70 c10 short stepside i am bagging.. i want to know what kind of track bar do i need were can i get one. thats the last thing i need to finish my frame
08-23-2011, 08:08 PM | #2 |
Kid's Mechanic
Re: help help help.. track bar
Suspension forum will have answers , Moving this for you
08-24-2011, 11:15 AM | #3 |
1965 Chevy C10, 2005 4.8L/4l60
A double adjustable, I would say. How much of a drop would you be going, POL, CPP and others have them but depends on your drop too, some relocate the mount onto the trailing arm mount and some are just replacements. Check out the vendors forum above.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-24-2011, 03:22 PM | #4 |
We make a pretty nice one, that also includes a new mounting bracket for the driver side frame rail. It sells for $149.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
08-24-2011, 04:13 PM | #5 |
Sorry Nate, I didnt mention your products
Crispo, Nate has a very good reputation around here, his products are all top quality and his CS is superb! Sorry for the shameless plug Nate, just spewing what I have read/heard. No you dont owe me anything...JK.
08-24-2011, 06:01 PM | #6 |
ok thanx.. everything is stock i only but a c notch on it, i know it wont be that low, but thanx i think thats the one im getting, easy 2 install?
08-24-2011, 07:08 PM | #7 |
You will have to unbolt your trailing arms to install the shim on the driver side and the mounting bracket on the passenger side. You will have to remove some rivets that hold the original mounting bracket on the driver side frame rail to remove it. You will a couple of the holes that held the original trac bar bracket to locate the new one, and drill a few more. Not overly difficult, if the rivets and u-bolts cooperate.
08-24-2011, 10:05 PM | #8 |
Here is one installed from Porterbuilt.
08-24-2011, 10:09 PM | #9 |
One word. Porterbuilt.
Posted via Mobile Device |
09-09-2011, 07:45 PM | #10 |
ok porterbuilt, one last question before i buy this.. on the ends of the bar, how are the round pieces that hold bolt go in.. r they screwd in or do they slide in.. i dnt see any thread on the 2 pieces.. never upgraded one before sorry for asking?
09-09-2011, 08:02 PM | #11 |
They are screwed into the end of the bar, this allows them to be adjustable.
09-10-2011, 02:03 PM | #12 |
Like clyde mentioned, the rod ends are both threaded (one right hand and one left hand) this allows the bar length to be adjusted without unbolting it.
09-12-2011, 08:28 PM | #13 |
im having trouble ordering it. how do i do it, there is nothing that shows buy it on that site
09-12-2011, 09:01 PM | #14 | |
09-12-2011, 09:02 PM | #15 |
Awesome product. Just picked one up for myself.
10-17-2014, 01:13 PM | #16 |
Will the PB trac bar work with the CPP notch?
