Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 08-23-2011, 08:55 PM   #1
bigblock73
yeller
bigblock73's Avatar
1979 tach cluster
Nice tach cluster removed from 1979 K10 that had a 4-speed on the floor (no shift indicator). No broken tabs, wiring cut but plenty long to splice into. Un-tested, but it looks very clean and in operable condition. Pics to follow later tonight. $120 shipped to anywhere in the lower 48 states.
bigblock73 is offline   Reply With Quote
Old 08-23-2011, 11:41 PM   #2
54Caddy
GM Addicted
54Caddy's Avatar
Re: 1979 tach cluster
interested.. Think you can test it??
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 08-24-2011, 10:36 PM   #3
6772fan
Active Member
6772fan's Avatar
Interested as well. Put me in line after 54Caddy.
Lane
1979 Chevy SWB- (Second owner- Father in Law was first)
1979 Chevy Silverado SWB-Red/Red
6772fan is offline   Reply With Quote
Old 08-25-2011, 05:30 PM   #4
bigblock73
yeller
bigblock73's Avatar
54 caddy, I can try to test it this weekend.
FYI to all. I bead blasted the black gauge ring, it had a little rust on the face...new paint on it and it looks good as new. I will also be touching up the needles, they are faded a little.
Old 08-25-2011, 08:11 PM   #5
spudz
spudz's Avatar
Put me in line as well... my 79 c30 will thank u!
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 08-25-2011, 11:42 PM   #6
54Caddy
GM Addicted
54Caddy's Avatar
if you could do that jeff that would be great. Let me know how it works. and just a question if i do buy it how hard would it be to move the odometer to match mine or could i just swap speedo units?
..Mac’s Garage..
IG:MacsGarage
Old 08-26-2011, 11:06 AM   #7
tkeduk8r
tkeduk8r's Avatar
Jeff,
I know I hijacked your threadm but I have done a few of these and Its really no that hard.... Hardest parts are taking hte needle off (work slowly and pry to the closest part of the mounting shaft) and IIRC couple small screws to remove the face... OR I would just swap your speedometer over to the tach cluster by removing the 1) clear plastic, 2) block gauge surround that jeff painted, and 3) then the 3 (7mm or 1/4 inch) flanged self tapping screws that hold the speedo into the housing.... Ill go back to surfing now ...
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 08-26-2011, 12:28 PM   #8
bigblock73
yeller
bigblock73's Avatar
Thanks for the insight Mike!
