View Poll Results: Which routing do you like more???
Pipes run outside the frame the entire way back 7 43.75%
Pipes run inside frame rails and cut the frame aft of the cabin 9 56.25%
Voters: 16. You may not vote on this poll
Old 08-24-2011, 09:11 AM   #1
nibs
JRods Garage
nibs's Avatar
Side exit exhaust opinions...
Hey guys, I know this has been brought up on this site many times before but the threads were a couple years old. I know we have all become smarter and newer stuff has shown up in the scene since
Now, Ive been doing some searching around here and google for pics and ideas for running side exit exhaust on my 71. Here is an idea of how it sits to the ground when aired out
Ok, with that shown,
Idea #1 - I have seen some guys run the pipes to the outer sides of the frame right at the engine compartment and ran it along the outer side of the frame. Like this truck
The drawback on this is that the pipe is visible from the side of the truck. IMO drawing your eyes towards it and not the truck. But easily accomplished.
Idea #2 - I ran across this truck and I kinda like how this is run. the pipes are run on the inside of the frame rails and right after the cabin, cuts a hole through the frame and I would run the muffler in the little pocket between the frame and bedside, then dump the pipe right before the back wheels.
The drawback here is a ~4" hole in the structure of my truck. Would boxing the frame AND the hole recover the strength of the frame? I see thats exactly what this truck did. But the overall product looks nice and stealthy.
I want your guys' opinions on this... VOTE AWAY!
Orange Julius-My dropmember'd, LS'd, SWB street machine...
nibs is offline   Reply With Quote
Old 08-24-2011, 10:40 AM   #2
Lee H
Lee H's Avatar
Re: Side exit exhaust opinions...
Idea 1 is how I have had mine for many years.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 08-24-2011, 11:34 AM   #3
nibs
JRods Garage
nibs's Avatar
do you have any side shots of your truck? Id like to see how visible they are
Old 08-24-2011, 11:41 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
I think there is adequate room to tuck it high enough that it won't be visible. I would consider option #1 if you can route it under the frame up front without creating clearance issues.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-24-2011, 12:11 PM   #5
nibs
JRods Garage
nibs's Avatar
Here is roughly what I have for space. Keep in mind that the valves are going to be relocated before the pipes are run to under the bed. They were just put here for temporary use.
The cab mounts and the cab support(i think thats what you would call it) block up alot of the space...
Old 08-24-2011, 12:27 PM   #6
vin63
It's Better With Nitro
vin63's Avatar
Your idea #1 are photos of my exhaust. Here's an older photo of my truck while I was dismantling it (exhaust still mounted). Other than the turndown in front of the rear tire, you really can't see the exhaust...I purposely mounted the exhaust above the bottom of the frame for clearance since I have a steep approach driveway.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-24-2011, 12:34 PM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Mine ran on the outside of the rails, and the mufflers were beneath the cab. You canbarely see where the exit is, right in front of the wheel opening. None of the piping or muffler showed. Right now, the pipe ass'y is laying beneath my new cab, on the dolly.
Early Classic has a crossmember, that locates the front of the rear trailing arms, and it also includes 4-inch holes for routing exhaust pipes.
Member Nr. 2770
Old 08-24-2011, 01:24 PM   #8
nibs
JRods Garage
nibs's Avatar
Hmmmmm, that looks good. I wonder if the 63 had the same measurements as far as how much frame the body covered
Old 08-24-2011, 01:29 PM   #9
nibs
JRods Garage
nibs's Avatar
How big of piping did you use? Does it rattle against the body or frame at all? Maybe any pics of under the hood to see how you routed the pipes after the manifolds? I like it though
Old 08-24-2011, 01:34 PM   #10
vin63
vin63's Avatar
From your air valve photo, the space looks very similar. Also, I'm running a 3-inch diameter exhaust, which is a little excessive. If you run something smaller diameter, it will provide you more wiggle room. The other thing is I mounted my muffler under the bed, so that helped in my case.
Old 08-24-2011, 01:50 PM   #11
nibs
JRods Garage
nibs's Avatar
Yea, I would do mine just like yours. I like having the muffler not under the cabin. cuts back alot of drone and cabin noise. Who did your exhaust work? I notice you are pretty close to me
Old 08-24-2011, 02:37 PM   #12
vin63
vin63's Avatar
I usually fabricate my exhaust systems. If I do more complex systems with bends over the axle housing, etc., I'll have a muffler shop bend some sections for me.
Old 08-24-2011, 04:19 PM   #13
nibs
JRods Garage
nibs's Avatar
I should really invest in a welder...
Old 08-24-2011, 04:28 PM   #14
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
i had mine done two weeks ago
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 08-24-2011, 04:45 PM   #15
nibs
JRods Garage
nibs's Avatar
Looks nice! But Id be dragging those bad boys... Sittin a little too low
Old 08-24-2011, 07:47 PM   #16
Lee H
Lee H's Avatar
Even at rocker eye level you can't see mine except for the exhaust tip.
Old 08-24-2011, 09:23 PM   #17
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Best I can do is go take pix of the pipes, tomorrow. They are 2.5-inches in diameter back to the Flowmaster 40-series mufflers and then 2.25 out of the muffler. Let me take the pic tomorrow and you can see how they were made. Unfortunately, the truck is disassembled....completely. Cab setting on a dolly; chassis on stands....with nothing attached and the bed/front cap somewhere else. So, nothing to show as to how it looked.
As for noise....no rattles at all. I had a good muffler man. On the other hand, the mufflers and the exits as they were, reverberated very nicely from any solid object to the side of the truck. Yep, very enjoyable...and loud enough to drown out the annoying sounds of my radio.
Member Nr. 2770
Old 08-25-2011, 05:46 AM   #18
nibs
JRods Garage
nibs's Avatar
Thank you for the advice guys. I think I have decided to go the route then. Wish me luck! Check out my build thread to see how they end up
