Old 08-24-2011, 10:03 AM   #1
jim-bob
Sound Proofing/Insulation
..getting ready to put some in resto 72 custom..hoping you fellows can recommend a name brand that y'all have had success with..
I'm ordering some parts from LMC today, wondering if theirs is any good..No name just called "multi-purpose": 3/8" thick x 4ft x 6ft $30.
jim-bob is offline   Reply With Quote
Old 08-24-2011, 09:24 PM   #2
jim-bob
Re: Sound Proofing/Insulation
...ttt
Old 08-24-2011, 09:38 PM   #3
70cst
70cst's Avatar
http://www.b-quiet.com/extreme.html
This is what I got. Very pleased with it. Got mine off ebay...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 08-24-2011, 09:38 PM   #4
FLcustom10
I'll be doing the same thing this weekend. I can't really answer your question because I haven't done it yet, but here is what the LMC multi-purpose insulation looks like waiting to be installed. I'm planning on using it as needed in addition to the LMC insulation /sound deadening kit.
FLcustom10 is offline   Reply With Quote
Old 08-24-2011, 09:59 PM   #5
jim-bob
..thanks..how much did you use..
Old 08-24-2011, 10:01 PM   #6
jim-bob
Is that the 4'x6'x3/8" ? and do you think it's top-grade?
Old 08-24-2011, 10:12 PM   #7
70cst
70cst's Avatar
Geee...I think is was 50 sq ft. To be honest I can't rememember but I am well satisfied with it...
Old 08-24-2011, 10:33 PM   #8
FLcustom10
It looks OK to me. Here's a closer picture. I don't really have anything to compare it to. It does seem that most guys recommend something else like B-quiet or Fatmat.
Old 08-24-2011, 11:27 PM   #9
stomper
Junior Member
stomper's Avatar
I used something similar to b-quiet. I found it in the roofing section at Home Depot. It came in an 8" or so wide roll. It did smell like a freshly poured asphalt road in my truck for a while but it stuck well, stretched a little to hug the floor, and made the truck quieter. I'm sure someone will say it contains carcinogens but I'm a risk taker.
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
Old 08-24-2011, 11:29 PM   #10
kevmcrae
kevmcrae's Avatar
I suggest using the BQuiet, Fatmat, or similar PLUS the foil backed padding you have from LMC. The LMC stuff does great for heat or cold "insulation" and not so well for sound deadening. I used both on the back wall, floor, and as far up the firewall as I could. Then carpeted as well. I used the sound deadening material on the back of my door panels too. I have a 454 that is pretty loud. when I first go tthe truck I had to drive home 4 hours with no interior work done yet. I literally couldn't get the stereo loud enough! Now it's very quiet, and warm in the cold Montana winters.
kevmcrae is offline   Reply With Quote
Old 08-25-2011, 07:41 PM   #11
jim-bob
...yeah, the B-Quite sounds like the one to use..
Old 08-25-2011, 07:58 PM   #12
Rochlow
I think I might use Lizard skin down the road.. It's a sprayable deadener..
Rochlow is offline   Reply With Quote
Old 08-25-2011, 08:09 PM   #13
john8746
john8746's Avatar
If You were close to me I e two rolls that they use in cold weather shipping keeps product from freezing has aluminum on both sides with air pockets between works great and cost was nothing
Free is always Good
C/10 John N.J.
john8746 is offline   Reply With Quote
Old 08-25-2011, 08:16 PM   #14
FLDBRED
You might want to use product called Peel-N- Seal.You can get it at Lowes,it's inexpensive and works great!
FLDBRED is offline   Reply With Quote
Old 08-25-2011, 08:35 PM   #15
ItsRandy
ItsRandy's Avatar
What is peel-n-seal normally used for?
ItsRandy is offline   Reply With Quote
Old 08-25-2011, 08:47 PM   #16
jim-bob
Free is always Good
..yeah John..that would be a trip..thanks anyway.
Old 08-25-2011, 09:28 PM   #17
bigsnookmaster
bigsnookmaster's Avatar
I used a product called Second Skin Damplifier Pro. It's a butyl based product, so no bad smells. I also used a liquid ceramic coating for heat protection, and a heat resistant foil backed insulation that they also sell. Real good stuff, and my cab is extremely quiet inside.
bigsnookmaster is offline   Reply With Quote
Old 08-25-2011, 09:39 PM   #18
MusicMan70
MusicMan70's Avatar
Peel and Seal is for insulating ducts....
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 08-25-2011, 09:57 PM   #19
2wd73blazer
Has anyone used spray in bedliner before?
2wd73blazer is offline   Reply With Quote
Old 08-26-2011, 06:43 AM   #20
FLDBRED
It is used in the roofing busines,to seal and prevent ice damage.If you do a search there is a lot of info on it!Some people say it leaves a smell,most agree that it doesn't. I haven't used mine yet.
Old 08-26-2011, 09:26 AM   #21
Roscoep
Roscoep's Avatar
Just got through insulating my 67 Camaro with Eastwood's Thermo-Coustic. I am very pleased with the material and the installation. Going to do my C-10 with the same product.
Robert
71 Chevy SWB
Roscoep is offline   Reply With Quote
Old 08-26-2011, 04:20 PM   #22
jim-bob
..sure would be nice if you would come back on here after about 2-wks and let us know what you think..It seems like it may be a good product!
Old 08-27-2011, 12:32 AM   #23
ETsC10
Hand Crafted C-10
ETsC10's Avatar
When I purchased, I chose Second Skin products also...
after many days of research! Not cheap but, I think,
the best of the best.
IMHO...
Other than price, there's little to say good about
the flexible flashings sold at stores. If your truck
gets hot or is air tight, that stuff will smell forever
(I know this from experience!) plus the sagging
and adhesive breakdown is not appropriate for
vehicle use. Keep it around your house windows.
ETsC10 is offline   Reply With Quote
