Old 08-24-2011, 01:51 PM   #1
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Issues with the 71 big block
So my truck won't crank when its hot. I suspect the starter solenoid? Does that make sense that its temperature dependent? It has a 402BBC with hooker headers. The lights dim a tad when the key is in start positioin but theres no click or anything.
Also, looks like a real pain to get at with the headers on there. Should I yank the engine since I'd like to redo the valve guides while I'm at it?
Jud
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 08-24-2011, 06:31 PM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: Issues with the 71 big block
You can put a heat shield around the solenoid and get a bigger gauge pos. wire from the battery to starter. That helped on mine.
67 gmc custom lwb dakota truck. Sold...And bought back... And sold again...
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 08-24-2011, 06:55 PM   #3
Vintage Windmills
Vintage 4x4s
Eric good ideas. Looks like i may have to remove the headers though to replace the positive cable.
Old 08-24-2011, 09:56 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
I put a mini starter on my 454 and cured my hot start problems. I guess the extra room around it made the difference.
LockDoc
Leon
Old 08-24-2011, 11:59 PM   #5
72 K20
72 K20's Avatar
I had a 69 C10 and a 71 GMC tonner with big blocks and headers. On the 69 I fought the hot start problem and every other month burned up starters until I switched it over to a fender mounted solenoid. After that I never replaced another starter on that truck. When I put the big block in the tonner I switched it to the fender mounted solenoid and never had a problem with it.
Some people don't like the fender mounted ( ford style ) solenoids but it works, and seems to let the starters live longer.
72 K20 is offline   Reply With Quote
Old 08-25-2011, 09:55 AM   #6
Vintage Windmills
Vintage 4x4s
Thanks guys, good input, I've also heard the mini starters help and I like the idea of a remote solenoid. Would be easy to service on the fender. I could probably make a sheetmetal cover to help keep it looking clean too.
I'm still wondering though- should I pull the engine to do the heads and replace the starter? These headers wrap around it big time.
Old 08-25-2011, 01:40 PM   #7
QKENUF4U
QKENUF4U's Avatar
QKENUF4U is offline   Reply With Quote
Old 08-25-2011, 01:45 PM   #8
Shyguy
Junior Member
Shyguy's Avatar
I have a 454 in my '71 with Hooker headers and have heat soak problems. We are taking the engine out of the '71 lwb and putting it in my '67 which is on '69 swb frame so we will be putting a mini starter on the 454 along with a remote solenoid.
I think a combination of the mini starter and the remote solenoid should fix the heat soak problems.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 08-25-2011, 02:00 PM   #9
taank
Loosen header. Valve seals can be done in car
taank is offline   Reply With Quote
Old 08-25-2011, 04:05 PM   #10
landsurvey1
landsurvey1's Avatar
Switched to a mini starter and remote solenoid and havn't had a problem ever sense. And this is a bbc 454 w/headers in Phoenix, Az. where the temp will reach 114 today.
landsurvey1 is offline   Reply With Quote
Old 08-25-2011, 08:20 PM   #11
Vintage Windmills
Vintage 4x4s
Any brands of mini starters to watch out for? are they all good?
Old 08-25-2011, 11:03 PM   #12
landsurvey1
IMO use a new starter and not a rebuilt one. I bought mine at NAPA.
Old 08-25-2011, 11:14 PM   #13
Shyguy
Junior Member
Shyguy's Avatar
The folks on the Chevelle discussion forum seem to like the mini starters sold by DB Electric.
I checked out their web-site and the prices seem real good.
