![]() Join Date: Nov 2002
BBC with 177 blower, can it be kept underhood??
As the title states, my son's 67's will be getting a B&M 177 blower and am wondering if anyone else is running one, and if so, would it stay under a 2 "cowl hood, or would I need to go to a 4"? Any pics would be great. I'd really not cut a stock hood up and having anything sticking out.
Re: BBC with 177 blower, can it be kept underhood??
I doubt it will fit even with a 4" cowl hood
Champagne Taste on Beer Budget
Why not?
The 177 is not the huge 8-71 blower but the more compact version. All I know is it will to close on the 4" cowl hood.
Coming Soon: Project 1970 Country Truck |
It had pleanty of room on the small block, I'm just unsure how much taller a BBC is over a BBC. I was hoping with a drop base air cleaner that I could get it down low enough....
![]() Join Date: Oct 2005
Don't know if it helps, but I got a 142 on a small block sitting under the stock hood.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
~Rest In Peace~
im sure it will i got 871 and have just the scoop sticking out ,so im sure that 177 fit no problem
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
I built it
underhood?!? id be puting spacers on it to GET it to stick out
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
Anybody else? Anyone have pics by chance??
I'll get you some pics when I get home from work. I have a BBC with a 177 and it sits about like fastwillies. It might work on a 4", doubt it will on a 2".
Posted via Mobile Device |
#10 | |
It might they are 6" from the bottom to highest point but overall height from the bot of manifold the differance is only about 1.1/2 inches with the 177 being shorter than the 871 here is a post with dimensions from offshore http://www.offshoreonly.com/forums/g...77-height.html Last edited by mbgmike; 08-25-2011 at 08:49 PM. |
