Old 08-24-2011, 02:40 PM   #1
hartbraker
4X4 Rear Disc Conversion k30 & k20
I got some great information from a the owner of OFFROAD DESIGN in Colorado.... they have a rear disc conversion kit that is applicable for any 14 bolt full floating axle....
The kit is being shipped currently but if you'd like to see it... go to the website... www.offroaddesign.com/
I'll post pictures as soon as I can. Definitely looking forward to this addition to the old 1 ton. It reuses factory k20 calipers from 81-87. No fabrication required... the kit bolts on. VERY COOL
1986 Chevy Silverado k30: factory air, tilt wheel, 454cu 7.4L, Turbo 400, NP205, Corporate 14 bolt, Dana 60 front, 4.10 gears, SRW, long bed, standard cab... MY TRUE LOVE
hartbraker is offline   Reply With Quote
Old 08-24-2011, 02:43 PM   #2
hartbraker
Re: 4X4 Rear Disc Conversion k30 & k20
here are some pictures from the site
Old 08-24-2011, 05:48 PM   #3
russgt
russgt's Avatar
I have ORD's kit on 1 of my 14 bolts, It fits/works great. I also have Ballistic's kit on another 14 bolt. Both seem to be worth the money.
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 08-24-2011, 08:14 PM   #4
my4by2
my4by2's Avatar
We swapped in a 2005 model HD rear axle into my '77 - it already had disc brakes with the integral parking brake so it worked out great! A lot of those swap kits have "iffy" parking brake set-ups on 'em...
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 08-25-2011, 01:41 AM   #5
Mr. 250r
Mr. 250r's Avatar
I also went with a newer rear end from an 06 with factory discs after reading my4b2s build although those bolt on's are alot cheaper in price i liked the idea of factory discs over a bolt on kit ill be doing a thread soon on the swap
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 08-25-2011, 11:05 PM   #6
67_SS396
I love the rear discs on my rock crawler. It's not driven on the street, so no need for a legal parking brake. I use a line loc to the rear for doing front digs, tighter turns or parking n the trail.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 08-26-2011, 05:01 PM   #7
thirdstreettito
Resident of Here
thirdstreettito's Avatar
DIY4X has a great kit as well, plenty of 14bFF kits.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 08-26-2011, 08:18 PM   #8
my4by2
my4by2's Avatar
The shop building my truck (WFO Concepts) has a disc brake conversion for the 14-bolt as well:
http://www.wfoconcepts.com/cr/14-Bolt/3189/3354
They make the parts themselves & do killer work!
Old 08-26-2011, 08:32 PM   #9
Mr. 250r
Mr. 250r's Avatar
Out of curiosity my4by2 what are the 4point brackets for I assume the rear shocks and something else?
2003 1500 Silverado
Old 08-26-2011, 08:35 PM   #10
my4by2
my4by2's Avatar
If you're referring to the ones on my rear axle, those are for the torque arms they built for it - the other mounting end is up forward on the frame.
