08-24-2011, 06:43 PM | #1 |
block hugger headers
Hello everyone! Have a problem with my block hugger headers not fitting on 52 chevy pickup. Have a mustang II front end and have not welded motor mounts in yet but no room for clearence. Anyone have any suggestions or have a type of header that works? THX Jason
08-24-2011, 07:13 PM | #2 |
Re: block hugger headers
what engine?
08-24-2011, 08:09 PM | #3 |
if you have not welded in motor mounts , how is there no clearance?
put headers on and weld mounts to fit... |
08-24-2011, 09:33 PM | #4 |
These are from a '52 chevy, and sometimes you have to cut the frame to get the steering shaft to clear.. using block hugger headers..
08-24-2011, 10:39 PM | #5 |
i used a patriot H8065. it doesnt look like it from the picture but there is about 1 inch clearance around the steering shaft.i used the stock frame and a mustang II ifs with no modications. draw back is that they are about $275 uncoated
08-24-2011, 10:42 PM | #6 |
08-24-2011, 10:43 PM | #7 |
383 stroker
08-24-2011, 10:46 PM | #8 |
well my helper was getting ready to weld the motor mounts and he said that he thinks that if i had block headers that the first and last pipe went behind the two center he would have room.
08-24-2011, 10:50 PM | #9 |
my headers are different than yours. the first and last pipe are in front of there two center pipes.. yours looks great!! no problems with yours?
08-24-2011, 11:54 PM | #10 |
Here is a picture of the steering and motor mounts in a '51 suburban, the frame should be the same as your's.. does this give you a better look?
