Old 08-24-2011, 06:54 PM   #1
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
What is this Panel Called?
I have the lower cab corner [Red Box], but the area I have enclosed in the green box was damaged at one time, and the previous repair was done with the old 'drill holes and pull the dent out with a screw' method.
Once I got the bondo off, I see I can clean up the panel, but wondered if there is a place to get that upper corner.
Also,
What is that panel area called?
66 C20 Service Truck:
Old 08-24-2011, 07:20 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: What is this Panel Called?
Old 08-24-2011, 07:28 PM   #3
LostMy65
LostMy65's Avatar
^Thanks,
#13 = Pillar, Body Lock
I think I've heard some here call it a Quarter Panel.
Old 08-24-2011, 11:59 PM   #4
Captainfab
60-66 Nut
I might have that piece I can cut from a junk cab. If you can get me a couple dimensions I will see if what I have will work for you.
Old 08-25-2011, 12:17 AM   #5
LostMy65
LostMy65's Avatar
That would be great.
I just got through texting a guy here in OC that had a total junk cab. Too bad, I just missed him scrapping it.
I'll get the measurements this weekend.
