Old 08-25-2011, 12:06 AM   #1
85sierraclassic
85sierraclassic's Avatar
th350 vs sm465
so as of right now my truck has the sm465 and 205 combo. but today i ran across a good deal on a 350 trans and 205 combo and trying to decide if i really want to go back to and automatic or not, but real question is is whats the difference in length if any and whats your opinioins on the pros and cons of each.?
85 GMC sierra classic : 350, 4spd, 205, 3.42s, 35s
85sierraclassic is offline   Reply With Quote
Old 08-25-2011, 09:24 AM   #2
tucsonjwt
Re: th350 vs sm465
Stay away from 350. Unless you are upgrading to an overdrive automatic it is not a good swap. 700R4 or newer is the only swap worth doing, and I would still keep the SM465.
tucsonjwt is offline   Reply With Quote
Old 08-25-2011, 11:55 AM   #3
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
Re: th350 vs sm465
sm465 all the way
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 08-25-2011, 12:04 PM   #4
85sierraclassic
Re: th350 vs sm465
well i love the sm465 for the reliability and all but and automatic would be nice at times, is what i was thinking. but ive never had good luck with automatics in this truck thats why i went to a 4spd in the first place lol so maybe i should just leave it like it is. plus would save alot of work. but $75 for a 350 and 205 is just hard to pass up lol.
Old 08-25-2011, 01:01 PM   #5
Your41Plague12
Your41Plague12's Avatar
Re: th350 vs sm465
For that price, buy it and re-sell it. Keep your setup, it's much more reliable in the long run.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 08-25-2011, 11:35 PM   #6
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: th350 vs sm465
350s aren't that strong and have no overdrive if you went to an automatic TH400 be way better but I say you still stick with the sm465 cause they rock!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 08-26-2011, 04:07 AM   #7
85sierraclassic
Re: th350 vs sm465
ok what makes a th400 better than a th350?and im not a fan of overdrives at all unless you spend enough money to make up for all the factory flaws lol but ive never really understood what makes a th400 so great? and dont get me wrong i love my 4spd for about everything but sometimes the autos are nice.
Old 08-26-2011, 12:47 PM   #8
Edahall
Re: th350 vs sm465
SM465
Pros:
Strong
Good power transfer
Better fuel economy
Cons:
You have to shift
TH350
Pros:
Don't have to shift
Cons:
Weak
Expensive to rebuild
Loss of power from non lock up torque converter
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 08-26-2011, 01:09 PM   #9
Your41Plague12
Re: th350 vs sm465
TH400's are just stronger internally, also. Everything is much heavier duty. For a 2wd with stock tires or something, a stock TH350 will do just fine. For a 4x4 or anything with a built engine or bigger tires, etc. a TH400 is the way to go.
Steve
Old 08-26-2011, 03:19 PM   #10
85sierraclassic
Re: th350 vs sm465
ok makes sence lol
Old 08-26-2011, 08:55 PM   #11
79k30dually
Re: th350 vs sm465
I believe the length is the same, I've seen th350's take alot of abuse. Th350's are easy and cheap to rebuild. Daily driving is alot different from towing, I like an auto for daily driving, but for heavy towing, in my dually I have a 465 and 205. With the 454 running, clutch out, posi's doing what they do, something WILL move. I'd buy it for your next project, it's an investment. Good luck, Ron
79k30dually is offline   Reply With Quote
