Old 08-25-2011, 01:48 AM   #1
givengold
Heater blower
I have a 72 AC Blazer. The other day, I noticed that the fan motor was slowing down and speeding up. The switch was set at high. The next day, no fan at all. Where do I look first? This is an AC cab, but the AC part is not funtioning at the moment. I was just running the fan.
givengold is offline   Reply With Quote
Old 08-25-2011, 10:26 AM   #2
chilihed
Re: Heater blower
Check the ground first.
chilihed is offline   Reply With Quote
Old 08-25-2011, 11:16 AM   #3
webfoot
Re: Heater blower
Does it do the same on the other speeds?
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 08-25-2011, 01:11 PM   #4
sleepertruck72
sleepertruck72's Avatar
Re: Heater blower
Check the ground strap, clean it up while youre at it. Check the harness/connector at the motor to make sure it is getting battery voltage. Also check out the resistor pack behind the glove box. I had one that had surface rust causing low speed to not work... Hope this helps
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
