Old 08-25-2011, 01:42 PM   #1
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Gm v6 hei ?
Is this the same distributor that is used on an Inline 6?
GM HEI Distributor Chevrolet 4.3 V6 6cylinder Brand New
Link:
http://cgi.ebay.com/ebaymotors/_W0QQ...sQ26Q5ffviQ3d1
66 C20 Service Truck:
Old 08-26-2011, 09:06 PM   #2
C-10 simplex
Re: Gm v6 hei ?
i don't think so; The cap may be interchangeable, but that's about it.
C-10 simplex is offline   Reply With Quote
Old 08-27-2011, 06:07 PM   #3
HEI451
Re: Gm v6 hei ?
Small-body HEI's ARE available as a conversion to a stock later model points V6 distributor with the window in the cap.
HEI451 is offline   Reply With Quote
Old 08-28-2011, 10:30 AM   #4
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Re: Gm v6 hei ?
They're not the same, but if you want HEI for a straight 6 they can be found on eBay or on straight sixes from the late 70s/early 80s. I bought the HEI for my nova's 250 on eBay and was impressed at the price and quality of it.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 08-28-2011, 01:37 PM   #5
HEI451
Re: Gm v6 hei ?
The issue is, between the inline early/late 6's and the GMC V6's, they do not interchange into the engines the same, different posts and gears. As far as being phased correctly for the V6, yes they are an even fire setup, 120 degrees between firing pulses, and work, but, if it don't fit the engine, and don't drive the oil pump..it don't work!
As I said, there is a conversion, not a "drop in" system, that adds real HEI to the later V6 points distributors by completely reworking them. This is NOT a large cap HEI grafted onto the point body and gear, this is a completely redone, remote mounted coil HEI, looks close to stock because it uses the stock points distributor, works better than the coil in cap HEI's.
Search google.
Old 08-29-2011, 08:32 AM   #6
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Gm v6 hei ?
Pertronix would do all that.
'68OrangeSunshine is online now   Reply With Quote
Old 08-29-2011, 11:43 AM   #7
HEI451
Re: Gm v6 hei ?
PerTronix IS NOT AN HEI, nowhere near it. They are a TCBI (transistor controlled breaker-less inductive). They make the same output voltage as a brand new set of points makes, the first spark out of them, and doesn't degrade from pitting and wear on the points face, but, they do not make anywhere near HEI voltage levels, NO MATTER THE COIL USED , NO MATTER THE INPUT VOLTAGE, RESISTED OR NOT, THEY DON'T MAKE ANYWHERE NEAR HEI SPARK OUTPUT LEVELS, PERIOD.
The advertising hype that replacement drop-in systems like PerTronix have received, has sure changed the truth about their spark output levels. This over hype advertising sure does sell a lot of junker ignition systems, though. Too bad, it gives a REAL HEI a really bad name from it all.
That IS the truth of it.
Anyone want a free PerTronix, I have about 2,000 of them out in 5 - 55 gallon barrels, all dead as a door nail, you can pick the one you want to be completely and totally frustrated with, and not have to pay for it.
Old 09-06-2011, 09:03 PM   #8
crazy longhorn
Fabricate till you "puke"
Re: Gm v6 hei ?
`ok then why does the Pertronix conversion (flying magnet), with an Accel supercoil run better than the HEI,s did in my ole 383? after 20000 miles why does it still run if it is infact "junk"?& why does it rev to 7200& dont skip a beat? crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-06-2011, 09:41 PM   #9
HEI451
Re: Gm v6 hei ?
You are lucky, the rest of them don't run that well. And, if that HEI had a stock epoxy in cap coil, I'd expect a match lit at the spark plug hole worked better than it did.
Old 09-06-2011, 10:03 PM   #10
crazy longhorn
Re: Gm v6 hei ?
OOps, I forgot....I did lite the match on all 8 holes, no need for them stinkin spark plugs(stuffed the kid under the hood)....it sort of freaked him out tho crazyL
Old 09-08-2011, 06:49 AM   #11
D13
D13's Avatar
Re: Gm v6 hei ?
So to answer the original question, no, the L-6 and V-6 4.3 distributors are different.
Both are readily available in yards, rebuilt or new off evilflay.
There are a couple of different HEI's available for the L-6, coil in cap, big cap remote coil, etc. There are 2 different shaft set ups, and since this drives the oil pump, be sure you get a complete package. They take different pick oup coils too. Either one will do just fine.
Pertronix works great on old tractors. For all others just get an HEI.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 09-08-2011, 10:43 AM   #12
Redcap
Re: Gm v6 hei ?
Pertronix units are crap. Fragile and prone to burning up.
Redcap is offline   Reply With Quote
Old 09-08-2011, 01:50 PM   #13
C-10 simplex
Re: Gm v6 hei ?
Can't you just change a v-8 distributor to a v-6 by changing the cap and star wheel and reluctor wheel?
Old 09-09-2011, 06:32 AM   #14
D13
D13's Avatar
Re: Gm v6 hei ?
By time you disassemble the two and swap out the parts, you could have bought a replacement and dropped it in. It's not like any of these are rare. To get the parts for the V6, you'd already have to be in posession of a complete unit, other than the housing, which rarely goes bad (might need bushings... cheap).
People do modify early L6 and V-6 (305) distributors to HEI's but only because there is no factory HEI's to be had. For any late model V-6/L-6/V-8, HEI's are plentiful and therefore cheap.
1987 2 ton
