Old 08-25-2011, 02:30 PM   #1
closer9
Can someone check these measurements? Is this K5 lifted?
Can someone tell me what the rear hub to fender distance should be for (approximately, I realize there are a lot of variables) a stock or lifted Blazer. The '79 I'm most likely trading for a in a few weeks is 23" from center of hub to the bottom of the fender in the rear. Don't have front measurements. Also, the front wheels seem set back really far compared to the opening. Don't notice this on Dad's '85 2WD pickup. Is that normal for a 4WD?
I'm trying to decide what to do about tires/wheels. I have a very nice set of 33/11.5/16's that I would like to put on it, but that means buying 16" wheels and a lift if they rub. Also considering talking Dad out of a set of 31/10.5/15's that are new,and on a truck he doesn't drive, but he's not really too interested in letting them go.
thanks!
closer9 is offline   Reply With Quote
Old 08-27-2011, 09:27 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: Can someone check these measurements? Is this K5 lifted?
I have a stock M1009, it's got heavier duty springs but otherwise seems to be about the same height as a factory civilian 4x4. I'll measure it tomorrow.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 08-28-2011, 12:15 PM   #3
68Timber
68Timber's Avatar
I'm at 21" from the fender lip to the center of the rear axle hub. The front axle is centered in the wheel-wells same as my 2wd K5. Post some pictures if you can.
John
74 Honda Z50 build
Old 08-28-2011, 12:26 PM   #4
68Timber
68Timber's Avatar
Here's a side shot of NCTyphoonKid's 4x4, this is what a stock K5 should look like.
John
74 Honda Z50 build
Old 08-28-2011, 10:59 PM   #5
closer9
Thanks... Going to try to get some good Pix this week.
Old 09-06-2011, 12:12 AM   #6
closer9
Well, didn't get to bring the Blazer home. Brakes needed more work than we had time for. Did get new sway bar bushings, tie rod ends and steering stabilizer. Also, pulled the bug guard and running boards off, and put on a set of 15x8 rallys with 255/60/15's. Still plan on putting on 33's.
Also, it appears there IS a lift on the truck, and it would seem about 2". The rear springs are new, and front appears to have an AAL.
Will be heading back down in a few weeks to fix the brakes. Guess I need to start advertising my Dodge...
Old 09-06-2011, 12:23 AM   #7
WarBeard
WarBeard's Avatar
Ive never seen a add a leaf used in the front....Blazer looks really good!
1978 C10 Silverado Big 10 350/350.. play toy
1990 V1500 Suburban 350/700r4..Daily driver
1987 K10 Silverado 383/400.. Wife's rig WRECKED!
1989 V2500 Suburban 350/400.. SOLD!
1974 C10 Custom10 LWB 350/350.. SOLD!
1974 C10 Custom10 SWB 350/400.. SOLD!
1999 Silverado Z71 LS1.. Wife's rig WRECKED!
On the hunt for a new project.......
I'm a Chevy guy.....I'm just not a "NEW" Chevy guy.
WarBeard is offline   Reply With Quote
