Old 08-25-2011, 06:53 PM   #1
mrjake7
Universal side molding
Has anyone ever used the universal side molding they sell at JC Whitney?
I was thinking of putting the lower molding on since I don't have the dough for a "real" kit. I'm not really trying to stay orginal, I just don't want something that looks cheap. Thanks for the help.
mrjake7 is offline   Reply With Quote
Old 08-25-2011, 07:57 PM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: Universal side molding
it looks cheap. Factory stuff or nothing imho.
brad_man_72 is offline   Reply With Quote
Old 08-25-2011, 09:50 PM   #3
turp mcspray
turp mcspray's Avatar
Save your $ for the real thing. You'll be glad you did!
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 08-26-2011, 11:37 AM   #4
mrjake7
Thanks for the input guys. Does anyone have any picture of trucks with the universal trim? Also, where can I get the best deal on factory stuff? How easy is the factory stuff to install? Mine doesn't have any trim on it now, so it would be a fresh install with no holes. Thanks again for the input.
Old 08-26-2011, 04:12 PM   #5
SWB4x4
SWB4x4's Avatar
This suburban is in Truck of The Month it appears to be universal stick-on moulding.... looks good in these pics..I'd like some more info from guys on what they are using and pics.
J.T.
1972 SWB 4X4 on 35"s with 6" lift all around 3/4 ton running gear with high steer and 4.88s 350/th350. SOON TO BE DONE:2" higher in front 37"s,LSX Swap,Hugger Orange & White Paint Scheme,Air Conditioning,Power Windows & Locks,Complete Gauge Kit,Tank Relocation,Double Din Nav with full Audio System.
My Build Thread http://67-72chevytrucks.com/vboard/s...=1#post4169140
SWB4x4 is offline   Reply With Quote
Old 08-26-2011, 08:01 PM   #6
mrjake7
That looks pretty good to me. I was actually thinking about the same style trim. Keep the pictures coming.
Old 08-26-2011, 08:25 PM   #7
bollybib
bollybib's Avatar
I'd say if you can obtain the kind of results shown in the pics, go for it. The thin lower universal makes the truck look leaner. The stock lower trim on 69&ups is kinda chubby.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 08-27-2011, 04:34 PM   #8
MVHandy
I think the stuff at JC Whitney will look like what it is, cheap, cheap, cheap..... I think a good quality stick on is the way to go for a nice looking, simple and clean driver. It's also easy on the budget. I used molding from Trim-Gard, lots of choices and proce was not bad.
I used a stick on upper and will use stick on to replace the lower, by the time I polish, replace woodgrain, buy clips and everyhting it would cost way more to use oem. If anyone wants to buy a full set of driver quality molding and go through the pain I have it....
MVHandy is offline   Reply With Quote
Old 08-27-2011, 07:16 PM   #9
mrjake7
Thanks for the info I will check out trim-gard. What do you plan on using for the lower? Do yo have a picture of what you did with the upper?
Old 08-27-2011, 08:42 PM   #10
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Salvage junkyard trim....?
John
1999 Toyota Tacoma 4x4
Old 08-28-2011, 12:13 AM   #11
SWB4x4
SWB4x4's Avatar
http://www.autoamenity.com/Body-Mold...UV-Molding.htm
*Mods sorry if I'm not supposed to post links?? I am not affiliated with this palce in anyway just something I found.
here is what I found that I am thinking of using they offer alot of GM type of trim and different sizes that will work and look similar to stock.
bottom molding I was thinking of using it is 2 & 1/4 width
or this one which is more textured looking in the middle
then this one for the top it is available in different widths
this stuff looks closer to the stock one because it is chrome on the outside and blk on the inside.
J.T.
Old 08-28-2011, 01:01 AM   #12
mrjake7
I think that looks nice. It would look really good on your pick up. Thanks for the info.
