power steering geerbox
So its leaking out of the top end of it, would that be the upper input shaft that needs replaced?
Thanks guys |
425hp409
![]() Join Date: Oct 2008
Re: power steering geerbox
If it is leaking where the steering shaft goes into it, that is called the "sector shaft seal"
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
![]() Join Date: Nov 2007
Mine looks like it leaks out of all of it.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
sector shaft seal ok i got it! thanks
webfoot im telling you once i get my truck looking pretty decent it wants to start leaking different places! |
Scrapper 1
if your have the factory gear box don't let go of it the auto parts store will sell you a less turning steering gear box have your rebuilt lot cheaper
How much does it cost to get them rebuild? Are they very difficult to do it yourself?
Wow, that question killed the discussion, didn't it.
I too would be interested in how to rebuild. I had been warned about the replacement stuff having a different ratio, so i would just as soon rebuild mine, but i'm a power steering gear box rookie, at best. |
The shaft that the pitman arm hooks to is called the sector shaft. The shaft that the steeing column hooks to is called the worm shaft. The seals are not hard to replace but a complete o-haul could be difficult.
If you google "Saginaw Box Rebuild - How To" there's an excellent how to you'll find on pirate 4x4
Also, look up "Saginaw Steering Box Rebuild - Smooth Steering" by four wheeler magazine for another good write-up. You should be able to get an idea whether it's something you want to tackle or not.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
Petroleum User
Has anyone had experience with a reman steering gear from LMC? The catalog shows them selling for $230+core.
![]() 1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto 2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto |
