Old 08-25-2011, 10:47 PM   #1
Indyuke
Trim clips
Anyone seen these things before? I pulled a nice set of upper trim pieces off a junkyard C10, and the door pieces were attached using these. I would like to find some so I don't have to drill holes in my truck to install the trim. The rest of the trim was held on using the original clips, but these actually held the trim on better than the original clips did. Is this original, or something aftermarket that I can get my hands on?
Indyuke is offline   Reply With Quote
Old 08-25-2011, 10:49 PM   #2
Lee H
Lee H's Avatar
Re: Trim clips
After market glue on. Should be able to find them though your local body shop.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 08-25-2011, 11:20 PM   #3
71 super
71 super's Avatar
Re: Trim clips
They are original GM. Were used in 71/72 . You can get them aftermarket from many venders. They use a 3m adhesive backing and hold pretty good, but when the let go, they are done.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 08-26-2011, 12:52 AM   #4
sanford66
sanford66's Avatar
Re: Trim clips
My 72 Cheyenne has those on the upper bedside trim. 71 super is right when they lose their sticky they are toast. You should be able to order them from any parts vendor. Joseph
1970 Chevelle Nomad station wagon
1966 C-10 lwb,250-six,granny 4speed
1966 C-10 lwb,factory A/C,Custom Cab
1954 Delray 2-door sedan [rat rod project]
sanford66 is offline   Reply With Quote
Old 08-26-2011, 01:26 PM   #5
Indyuke
Re: Trim clips
Sweet! Thanks guys
Old 08-26-2011, 07:48 PM   #6
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Re: Trim clips
I've been looking all over. Obviously in the wrong places. Any tips on who would carry these? I really need 'em.
Okay...It's a rat (no money for body work or paint yet). But the back (tailgate and tail lights) are getting the molding.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 08-26-2011, 11:46 PM   #7
71 super
71 super's Avatar
Re: Trim clips
Mag the trim on the tailgate and taillight HAVE to have the clips, to my knowledge the adhesive backed clips do no come in a size that will work for them(guess you could trim but would be pretty aggrevating)
Old 08-27-2011, 08:57 PM   #8
1GT1
Re: Trim clips
I had started another thread looking for these same clips. Can anyone help in naming a company that makes them. Thanks.
1GT1 is offline   Reply With Quote
Old 08-27-2011, 09:02 PM   #9
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Trim clips
3M makes a double-sided trim tape that might work for you, if your old clips have lost their grip. Kinda like Fix-A-Dent for re-attaching bits and pieces. Make sure you have an absolutely grease-free surface and no dirt.
Member Nr. 2770
Old 08-27-2011, 09:04 PM   #10
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Trim clips
Classic Parts of America sells them.
Part #62-883 for 69-72 upper trim
Part #62-885 for 69-72 lower trim
Keith
Convert to disc brakes.
Old 08-27-2011, 09:05 PM   #11
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Trim clips
Here's a link to 3M's product: http://solutions.3m.com/wps/portal/3...beS2Z15RR9ZVgl
Member Nr. 2770
Old 08-27-2011, 09:08 PM   #12
mrjake7
Re: Trim clips
Check http://www.classicparts.com/1969-72-...ctinfo/62-883/
mrjake7 is offline   Reply With Quote
Old 08-27-2011, 09:58 PM   #13
1GT1
Re: Trim clips
Thanks guys that's what I have been looking for.
Old 08-28-2011, 12:11 AM   #14
leddzepp
Moderator
leddzepp's Avatar
Re: Trim clips
www.truckandcarshop.com also carries them. I bought mine there. I replaced the crappy double sided tape that comes on them with 3M outdoor grade double sided tape. They have held perfectly for two years now.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 08-28-2011, 04:11 PM   #15
magwakeenercew2jh
Re: Trim clips
Since I'm putting on the rear trim only..... and, 71 Super clued me into the fact that you HAVE TO HAVE the holes for the stock trim clips to work in that area, I decide to fab some.
From the outside it goes:
- Trim piece
- 1/4 " flat washer;
- Small chunk of the 3M to hold on and space..
- 1" x 1/16" aluminum "bar" trimmed to about a shy 3/4"
to fit the inside lips of the trim;
- Another strip of 7/8" 3M trimmed to fit the exposed
portion of the "bar";
- The full 7/8" 3M trim tape all along the lip of the trim that will now fully
contact the paint on the truck.
I may cut the "bar" into several (maybe 1" strips) . I was going to use 5 four inch metal strips of the bar along this trim piece, for example. But maybe 10 1" "clips" made fronm the bar will spread the load and adhesion a little better. And maybe lessen the weight.
Oh, regarding weight. All this stuff is still as light as a feather. The weight of the aluminum "bar" is not a real issue. If I use the set-up as it is shown, naturally, the 7/8" 3M tape will run the whole length of the trim between the trim piece and the truck body.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 08-29-2011, 08:29 AM   #16
doodah man
doodah man's Avatar
Re: Trim clips
Can we take this thread to its next logical step?
How do you get the trim off and on the metal clips? I recently had a little fender bender (Doh!) and next to get this lower molding off, straightened out and reinstalled. It's still attached at the front. All the plastic sticky clips came loose.
1972 C-10 Deluxe
350 V8 - 350TH
We're not the jet set
We're the old Chevrolet set
doodah man is offline   Reply With Quote
Old 08-29-2011, 09:59 AM   #17
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Re: Trim clips
At the ends of the moldings there is a small bolt attached to a different clip which goes through the panel and uses a small retaining nut on the back.
By the way Wes at Classic Parts sells all the various types of clips for our upper & lower moldings.
Like the one on the left in the pic.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 08-29-2011, 10:26 AM   #18
doodah man
doodah man's Avatar
Re: Trim clips
I thought there might be a way to remove/install the molding with the metal clips still on the bedside, but I see how it works now. Remove the nuts and the molding comes off.
Thanks!
1972 C-10 Deluxe
350 V8 - 350TH
