Old 08-26-2011, 08:57 AM   #1
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
stock rubber or urathane body mounts pro or cons or advice!!
i am going to order cab mounts not sure what would be best for my set up o only need the truck mounts i have the rear suburban mounts any suggestions or past experiance would be a great help thanks!!
gostranger is offline   Reply With Quote
Old 08-26-2011, 12:20 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: stock rubber or urathane body mounts pro or cons or advice!!
Post number 12 on the following thread sums up everything I’ve read about urethane bushings and mounts. Sooner or later they are going to squeak. I had a 57 Chevy long ago with everything worn out in the front suspension, and the constant squeaking was embarrasing. I will never have interest in investing in a product that will cause me to relive that adventure:
http://67-72chevytrucks.com/vboard/s...light=urethane
Old 08-26-2011, 12:44 PM   #3
gostranger
gostranger's Avatar
cool thanks!!
Old 08-26-2011, 04:15 PM   #4
64fleetside
I have urethane cab mounts on two trucks, no squeaks. I guess there's not enough movement. But urethane suspension stuff WILL squeak eventually, IME.
64fleetside is offline   Reply With Quote
