Old 08-26-2011, 02:08 PM   #1
trapperjack
trapperjack's Avatar
lug nut question
I've been searching, but stilii confused. i have a 67 3/4 ton 4x4, drums all the way the around. It has aftermarket alluminum wheels on 3 corners, steelie on 1. the lug nuts holding the steelie on are the same as whats on the alluminum rims. Has been fine for bouncing around the pasture, but I'm getting her back on the road next week, I hope. I can't figure out which lug nuts I need to get for the steelie. I've seen 9/16, but also seen 9/16 was 71-72.
What should it be? I need to get some tomorrow.
Thanks.
1962 Chevy K10 factory 4x4 stepside longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=494632
1967 Chevy 3/4 ton 4x4 long bed (Henrietta) traded
1968 Chevy 1/2 ton panel wagon, V8 and powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=483345
1978 Ford F250, beater stepside
2008 Jeep Wrangler 4 Door
2010 Chevy 4x4 plain jane work truck
trapperjack is offline   Reply With Quote
Old 08-26-2011, 11:14 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: lug nut question
1/2 inch
I would remove one of the mad lug nuts, and look at the end of it. More often than not, the taper is the same on the steel wheel and on the shanked style lug nuts. I have literally gone thousands of miles like that.
Old 08-27-2011, 05:40 AM   #3
cdowns
cdowns's Avatar
i normally measure things to make sure of what is required
Old 08-27-2011, 12:01 PM   #4
trapperjack
Thanks ya'll. I'll take one in town with me, but seems like most of the parts stores nowadays just have things hanging on a peg, no one knows anything except how to look something up on a computer, if it ain't there it doesn't exist. I doubt if any of the ones closest to me have any studs to check the lug nut on.
The taper looks similar, but I didn't like the feel of it when I put the steel rim on, I feel certain it needs a plain old lug nut. I may end up going to all steelies anyway.
Thanks again.
Old 08-27-2011, 02:35 PM   #5
RossRinSD
RossRinSD's Avatar
Yeah, but where do you measure from? The belly button??
RossRinSD is offline   Reply With Quote
Old 08-27-2011, 03:41 PM   #6
ed2552
ed2552's Avatar
Just use a tape measure on the stud, or calipers if you have them...
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 08-27-2011, 07:47 PM   #7
trapperjack
Found some at the parts store. Looked exactly like the one I had taken off. For $2/each for the plain old factory style open nuts, I decided to use what I had. I re-tightened them, and it felt better this time too.
