Old 08-26-2011, 11:02 PM   #1
gr8one
steering column
will a 1988-1994 steering column work in a 1967-1972 chevy truck, or is there another steering column other than a van column, be modified to work in our trucks.
gr8one is offline   Reply With Quote
Old 08-27-2011, 08:20 AM   #2
gr8one
Re: steering column
no one
Old 08-27-2011, 02:44 PM   #3
dyrt
Re: steering column
I don't know about the 88-94 column, but i do know that a 73 to 87 column will work. It is the same length but it has a different transition cup(the cup part that flows from the upper column to the dash.) It bolts in the same way but you will need to make it fit in some ways. you will need to use a different intermediate shaft since it is a double-d instead of splined and will need a wiring harness adapter. Also, there is an ignition lock in the column that needs to be dealt with or you can just leave it if you want. right now i have one temporarily in my 69 just to steer the frame and cab around when i push it.
In my opinion, it doesn't look horribly out of place, but the van column definitely looks like it belongs there.
dyrt is offline   Reply With Quote
Old 08-28-2011, 12:41 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: steering column
these are very reasonable and their new.
http://www.classicperform.com/Store/...6772EPSC-T.htm
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-23-2011, 07:58 PM   #5
68 TT
Still plays with trucks
68 TT's Avatar
Re: steering column
I have one of the square body ones in my 69 K10 that I am in the middle of converting to work. I am trying to keep the ignition on the column and turn signal stalk mounted cruise & delay wiper controls.
If I stripped it clean and kept the ignition & wipers on the dash it would be much easier to retrofit.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 09-23-2011, 08:55 PM   #6
hugger6933
Re: steering column
I bought a 86 motor home the other day it is a chevrolet P30 chasis and the colomn looks like the truck tilt except the shifter is stright instead of angled. I already had one [motorhome tilt on the rack and it looks really close. I installed it into my 68 but tookit out when the turn signal switch was bad and I installed a van tilt instead.
hugger6933 is offline   Reply With Quote
