Old 08-27-2011, 09:01 AM   #1
teeitup
Just like to part out trucks!!
teeitup's Avatar
Whats the best way to clean out a gas tank
Well my blazer should be here soon, Tom said it has a dirty gas tank, is there anyway to clean oen out? If so what is the best way to do it? Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 08-27-2011, 09:26 AM   #2
NuttinSpecial
NuttinSpecial's Avatar
Re: Whats the best way to clean out a gas tank
Go to eastwood.com i think was the site. and they make a 3 atage kit that me and my dad used before. You put the first chemical stage in there and eats at the buildup, then flush it out with like a water hose, then the second stage is a neautralizer then you flush it out, and the third stage is like a sealer. Thats the best way. If you dont have time you can use one of those power washer type sprayers at those little pull in car washes. Just stick it in the tank and rinse til your content.
NuttinSpecial is offline   Reply With Quote
Old 08-27-2011, 12:39 PM   #3
cdowns
cdowns's Avatar
i've used my pressure washer to get stuff loosened up first/then a solution of oxalic acid(swimming pool suppliy section) let soak half hour or so// then rise out with pressure washer again// drin and blow out with compressed air or exhaust from a shopvac
if extremely rusty ,i'd finish off with POR tank sealer
Old 08-27-2011, 12:56 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Old school trick is to add some rocks to the empty tank, and to shake the tank to break loose anything that shouldn't be inside it. Of course, you should have already removed the pickup/sending unit. Oh, remove the rocks when you're done.
Member Nr. 2770
Old 08-27-2011, 01:00 PM   #5
BMERDOC
BMERDOC's Avatar
If you wanna out source the labor a radiator shop will clean it out, boil it and reseal it. Mine cost $125.00.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 08-27-2011, 01:05 PM   #6
FLcustom10
Was this the kit you were talking about NuttinSpecial?
I'm debating between that and taking it to a radiator shop.
http://www.eastwood.com/por-15-fuel-...epair-kit.html
FLcustom10 is offline   Reply With Quote
Old 08-27-2011, 01:44 PM   #7
RossRinSD
RossRinSD's Avatar
Yeah, but how do you know you got all the rocks out?
I've heard of people using ice, because it melts and you can pour it out.
I just take a piece of chain, put some bolts though it with nuts on them. Drop that down in there, and have a girl with big boobs shake it all around.
RossRinSD is offline   Reply With Quote
Old 08-27-2011, 04:00 PM   #8
ItsRandy
ItsRandy's Avatar
The best way to clean out an old gas tank...replace it.
ItsRandy is offline   Reply With Quote
Old 08-27-2011, 04:38 PM   #9
hjewell2
hjewell2's Avatar
Now thats the best advice yet, cheap insurance.
hjewell2 is offline   Reply With Quote
Old 08-27-2011, 04:48 PM   #10
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
I would say when the rattling stops when you shake the tank, they're all out.
Matt
'69 Chevy SWB Fleet, Primer Black; Project No Name
'06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold
'08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!!
'99 Dodge Dakota R/T, Intense Blue; DD, Sold
Originally Posted by longbed67 View Post
The tig welds are not the prettiest i have seen but they do have good penetration.
Originally Posted by oldblue1968chevy View Post
There are two things in life where penetration is really important.....and one of them is welding.
stealthy '69 is offline   Reply With Quote
Old 08-27-2011, 05:24 PM   #11
NuttinSpecial
Sorry Man i dont remember, its been about 5 years since we did it, thats where we got it and my dad said it was about $40 and it was enough to do 2 tanks. We had to wash 2 for an old jaguar and it was only 3 steps, if thats the only one on the website they may have replaced it with that 4 step one but that seems a little pricey
Old 08-27-2011, 09:20 PM   #12
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Used to be a company named Hirsch that had a gas tank sealer. It was what was used, after you got all of the rocks out of the tank. And, you'll know you got all of the rocks when it doesn't rattle any more. Oh, don't use gravel....get some that are about half the diameter of the biggest hole you use to put them into the tank.
Here's the link:http://www.hirschauto.com/products.asp?dept=4
Member Nr. 2770
Old 08-27-2011, 09:38 PM   #13
chipflyer
chipflyer's Avatar
Hey Randy, the old fellow down at D&G radiator will boil it out and seal it for $100. The option I took on the 36 tank was to wash it with my hot water washer, cleaning the remaining gummy crap with MEK and finally made it look like new clean metal filling it with muratic acid (swimming pool cleaner). Flushed it again with hot water for about an hour and then after a day the inside flash rusted and made a perfect surface for the por-15 tank sealer I coated it with. If you have it sealed make sure to use a sealer that will stand up to our crappy gas that has ethanol in it. If not it will turn the tank sealer to goo and create a whole new problem.
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 08-28-2011, 10:28 AM   #14
BIG ORANGE
BIG ORANGE's Avatar
1st depends on how bad of shape the tank is. I've used a 3 foot length of log chain in some tanks and shake well then rinse for long time then let dry out in sun. I like to use a clear plastic inline fuel filter inbetween the fuel pump and carb. that way I can monitor any residue that may collect in the filter. jmo
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 08-28-2011, 10:45 AM   #15
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
taking to a rad shop is the best bet. They don't boil them out, all that would do is clean the olf fuel and paint off, along with the protective coating in there originaly. It would leave the rust uneffected though. They'll probably use a steam cleaner and flush it for an hr, then either cut it open and gind the rist, or use the chemicals described already.
A new tank is an option, but not the best option. The replacement ones are thin, and don't bolt up properly. The original fits.
Old 08-28-2011, 11:40 AM   #16
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Funny....my best friend did this and it worked AWESOME!! You can even use ceramic stones or some other media if the "rock" concept is hard to get past.
prostreetC-10 is offline   Reply With Quote
Old 08-28-2011, 11:58 AM   #17
Shane
Shane's Avatar
I've seen it done with a short link of chain too ... drop it in along with the chemicals ... shake like hell ... dump it out.
Shane is offline   Reply With Quote
Old 08-28-2011, 12:33 PM   #18
nbrfd007
nbrfd007's Avatar
After you get you chain and chemicals in your tank, duct tape it up, put it in back of you daily driver truck for a week. It will do the work for you.
nbrfd007 is offline   Reply With Quote
