Old 08-27-2011, 10:52 AM   #1
J/D/S
solid back glass rubber gasket question
Hey guys I bought a back glass gasket from LMC and this thing is about an inch to big is it supposed to be?
John Bernard Books (The Shootist):
"I won't be wronged, I won't be insulted, and I won't be laid a hand on. I don't do these things to other people and I expect the same from them."
J/D/S is offline   Reply With Quote
Old 08-27-2011, 11:13 AM   #2
RossRinSD
RossRinSD's Avatar
Re: solid back glass rubber gasket question
Yeah, we thought the same thing when doing mine. It'll work.
Mine was so much bigger, I thought my GF had bought a small window instead.
RossRinSD is offline   Reply With Quote
Old 08-27-2011, 11:25 AM   #3
william-theglassman
william-theglassman's Avatar
Quality control aint what it used to be.Is your gasket with or without the locking strip (chrome or black)?sometimes i get gaskets a little small or a little big . 1 inch isnt that bad . set it in the sun and let it warm up for a while . we are upper 90s here so only a few minutes .also tape it to the glass and force it to shrink . or send it back and go to a glass shop and get a Precision brand gasket.if it takes the chrome or black strip just force the gasket on the pinchweld the glass will make it fit when its installed.
william-theglassman is offline   Reply With Quote
Old 08-27-2011, 11:28 AM   #4
william-theglassman
it is possible to have a glass that is too small if it is after market . if buying a new glass get pilkington .or you might still find some good ones in a salvage yard.
Old 08-27-2011, 12:36 PM   #5
J/D/S
No Chrome or black strip just plain rubber as for the glass I got of out of a truck at the junk yard.
Old 08-28-2011, 02:12 PM   #6
william-theglassman
should work fine .
Old 08-28-2011, 08:56 PM   #7
J/D/S
Thank you William very much.
Old 08-29-2011, 12:27 AM   #8
RossRinSD
RossRinSD's Avatar
Originally Posted by RossRinSD View Post
It'll work.
Old 08-29-2011, 09:11 PM   #9
youwish2bme
youwish2bme's Avatar
The rubber stretches so I've found you can bunch it up to get it to fit...
Dave
youwish2bme is offline   Reply With Quote
Old 08-30-2011, 11:10 PM   #10
rustyrodknocker
typical lmc gasket. if you can get it on the truck without having fall off you can propably get it in. if it is falling off faster than you can put it on trash it. if it is loose they can bunch up and will leak. like mine. im done with em.
rustyrodknocker is offline   Reply With Quote
Old 08-31-2011, 12:19 AM   #11
78 Chevyrado
how does it fit the glass itself? i found if it doesnt fit that well, i find something else. I got mine from classic parts of america and it fit correctly. IIRC you may still be able to get a GM replacement from the dealer. I saw some online a year ago or so...
78 Chevyrado is offline   Reply With Quote
Old 08-31-2011, 12:28 AM   #12
RUSHNBOBO
I got mine from LMC a few years ago and remembered wrapping around the glass and it was so loose it was hard to keep in place while setting the glass.
After we got it up on the cab and pulled the rope to set rubber, it pulled right in nice and tight, looks and works fine.
RUSHNBOBO is offline   Reply With Quote
