GEARHEAD
71-72 Chevy Radiator Support
I'm not sure if the 69-70 is the same though I think it is. This is from my 71 C-10 I'm restoring. I just found one that is in better shape. This one is pretty solid, but has some rust under the battery area. It's not rusted away completely like most are, but is usable as is.
GONE
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff Last edited by hgs_notes; 09-19-2012 at 09:02 PM. |
VA72C10
![]() Join Date: Mar 2008
Re: 71-72 Chevy Radiator Support
great deal! Are you shipping? If so, how much if you just wrapped it up in plastic and stuck it on greyhound
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
GEARHEAD
Greyhound to Richmond is about $70-80 depending on the weight. I guessed between 30-40 lbs.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
VA72C10
I should have figured that much. Killer deal at 50. Hopefully someone local picks it up!
GEARHEAD
bump
GEARHEAD
Still available
Just a Member
Darn shipping!!!! I would grab this any day...all day
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
GEARHEAD
Still available, also have GMC or 68 Chevy front sheetmetal for local pick up.
