04-09-2003, 05:16 PM | #1 |
Battery Relocation.
I was looking under my hood and thought "I don't want the battery there" also a bit of weight transfer. Where can I relocate it to ? I needed a new battery tray so the price is about the same for a battery box I assume.... any ideas would be great. Also I plan on smoothing out the bump there for the original battery tray to bolt to.
Thanks.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
04-09-2003, 05:27 PM | #2 |
Almost Satisfied
here
is what Lost Wages did with his. Slammed67 did something similiar so you might look at his web site.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
04-09-2003, 05:29 PM | #3 |
That looks good. I am thinking more along the lines of a box though. Good location.
04-09-2003, 06:01 PM | #4 |
Mike
I have a 98 ford van with 2 batteries.The second battery is mounted to the frame like lost wages.But it is enclosed.You might want to check with the local yards.They used this box from83 on.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
04-09-2003, 06:05 PM | #5 |
member #16
How about some pics of your truck?
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
04-09-2003, 06:06 PM | #6 |
Nothing fits but the oil
Summit has a battery relocation kit listed in their catalog for about $45.00. It has everything needed, box, cables, grommets, bolts....everything. I put mine in the bed on the passenger side.
Land of the free Because of the brave |
04-09-2003, 06:42 PM | #7 |
Fabricate till you "puke"
I have the Summit relocation kit, & have fabbed brackets to mount on the outside of the frame rails on the pass side(under the bed is a good place for it, & contained in a plastic box....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
04-09-2003, 08:22 PM | #8 |
one thing..if you plan to take your truck to the track..NHRA rules state, that if your battery box is not in the engine compartment, there must be a Kill switch located in the rear of the vehicle..it must be marked ON/OFF and have a turn type switch to control it..check your local rules...Jim
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
04-09-2003, 09:45 PM | #9 |
I made one that mounts in the exact same place as the one in the picture,cept mine is a box. I welded it up out of some angle and flat stock and put sheet metal panels on the inside. Even had some louvers punched in the sheet metal. I ran battery cable up to the front where the battery was and used the Moroso remote terminals mounted in the rad support.
04-10-2003, 12:06 PM | #10 |
I've often wondered if putting the battery behind the seat on the pass. side is do-able, don't know if there would be room, though. You do have your fuel tank relocated, right? Two other things with that would be how to route the cables and allowing for drainage from the battery tray (acid) or maybe putting the battery in a box. Just my .02.
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart 1998 Chevy 1/2 ton ex cab V-6 5 speed 1967 Chevy SWB - project truck; not started just yet |
04-10-2003, 12:37 PM | #11 |
lpaine: I have seen guys use TWO of the 6 volt dry cell type batteris (Optima) in the street rod circles. These batteries are smaller in size and when wired together properly you still have your 12 volts. Just an idea ... and they are small enough to fit behind your seat without the worry of spilled acid.
04-10-2003, 12:48 PM | #12 |
Dont think I would want a regular battery in the cab with me. Venting the fumes would be impossible and I have seen what happens to a hood when one of those things blows up. Now I have a gel cell or spiral core from Napa and you could use a Optima and I was thinkinking about mounting it inside all the way in the back right behind my pass side inner fender on my Blazer. Just dont know if there are many fumes from this type of bat. Just my thoughts.
72 2wd 307/AT/AC/TILT WHEEL 78 JIMMY HIGH SIERRA |
04-10-2003, 02:31 PM | #13 |
I don't have any way to post pics my scanner is not working I have to reload the program oh and the Cd drive is busted too so I can't reload it.
I think I am going to buy a battery box and mount it where Lost Wages has his mounted. John my truck is really coming along at a good rate now. I hope to have the body in paint by the middle of May. Time permitting. Thanks for all the Ideas . Later Mario
04-10-2003, 02:45 PM | #14 |
It's a catastrophic success.
Put you a tilt on it and your options are unlimited.LOL
04-10-2003, 02:51 PM | #15 |
Does not look the same any more .... Omost ready for paint still lots of work left though.
04-10-2003, 02:54 PM | #16 |
frame
04-10-2003, 10:50 PM | #17 | |
Seņor Member
Kenneth
04-11-2003, 12:46 AM | #18 |
i have to give all the credit to slammed 67 for the battery idea, i stole it from him.
04-11-2003, 08:09 AM | #19 |
Mike
XXL the battery box I have is sealed with a gasket around the lid and grommets around cables.It is on a 4x4 that gets used in the mud.It doesn't get dirty.
04-11-2003, 10:11 AM | #20 |
Spank 'em if you got 'em!
Lost Wages, your right about Slammed67's ideas. When you look under his hood you don't see anything except steering, master cylinder, and a fat black engine. Very clean.
Long Knight '71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick |
04-11-2003, 10:30 AM | #21 | |
Seņor Member
Thanks, Kenneth
04-11-2003, 12:02 PM | #22 |
My dad did not think it would be a good Idea to put the battery under the box for the reason it would be hard to service and the amount of dirt on our roads. but he said "it's your truck " I was like Dam Straight ! I am not worried if the battery is in a sealed box. I never explained that to him.
04-11-2003, 01:45 PM | #23 |
Mike
The one I have came stock as an auxiliary battery on my ford van.To service there are 2 nuts and bolts you remove.Below the bolts are a stud on each side.Back off the nuts and lift the box off the studs.Pop the lid off to get to the battery.
04-14-2003, 08:05 PM | #24 | |
Seņor Member
Re: here
Kenneth
04-14-2003, 08:30 PM | #25 |
Here's where I mounted my battery.
