Old 08-27-2011, 09:00 PM   #1
hugger6933
Is there a less expensive to
mount a big-block in the 68 chassis? The factory mounts for those years are hard to find and pretty pricey. I am not concerned with being all factory looking. I thought that I read later mounts could work but I am not sure if that is correct. I think my truck was a factory big- block, It has the high hump. Did all 3/4 tons have that? Being the this is a GMC I have found no trace of a SPID. My truck has been locally owened it's whole life and when I was younger I am thinking it was a 396 truck but it has a center boltv/c 350 in it now. I am planning a frame change to a swb 5lug suspension and I thiught that would be the perfect time to put in that 454 I have sitting and waiting to be called into duty. If someone could post some pics of the big vs small mounts I might could tell what I have if not maybe someone could answer about the later mounts working. Thaks for the help. Jim
hugger6933 is offline   Reply With Quote
Old 08-27-2011, 09:02 PM   #2
71swb4x4
71swb4x4's Avatar
Re: Is there a less expensive to
I don't know if all 3/4 tons had the high hump. I do know that all big blocks had them, and all four-speeds had them. I think some or all TH400's had them. So you could have a 6 cylinder with a 4 speed and it would have a high hump.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 08-27-2011, 09:22 PM   #3
hugger6933
My 68 has the orginal th400 in it. It should be awesome it will be a 5 lug bigblock with tilt tac/vac, speed warning, buddy buckets and factory air power steering and brakes. I cannot decide on the bed floor if it will be steel or wood. I am getting pumped thinking about it. I have'nt got to work on it for a couple of months. This mount question will need to be put to bed before I can put in my drive train
Old 08-27-2011, 09:30 PM   #4
Shyguy
Junior Member
Shyguy's Avatar
We put a '73 454 in my '71 using the '73 big block mounts.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 08-27-2011, 09:45 PM   #5
hugger6933
Thanks for the help I thought I read that I could use the later mount and would work. Now, is there any difference in the big and small block mounts after 73? Were'nt they all the same?
Old 08-27-2011, 09:47 PM   #6
VA72C10
VA72C10
VA72C10's Avatar
Yes, the 73-87 motor mounts work for big and small blocks and are a cheap alternative. They look like the 72 specific mounts but have a single hump at the top instead of two like the 72 mounts do.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 08-28-2011, 12:46 AM   #7
eagleuh1
eagleuh1's Avatar
My 68 C20 3/4 ton has 327 with TH400 from factory. 2 WD and has small hump.
eagleuh1 is offline   Reply With Quote
Old 08-28-2011, 01:00 AM   #8
ItsRandy
ItsRandy's Avatar
Wood.
ItsRandy is offline   Reply With Quote
Old 08-28-2011, 03:19 AM   #9
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
i seen some dudes use angle iron to mount there motors, weld to the chassis and bolt on the front of the engine
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 08-28-2011, 03:55 AM   #10
454stepside
i have an 84 sububan 454 th400 in my 67 and used the 84 mounts worked perfect i did have to drill a few holes to mount them but it was easy
454stepside is offline   Reply With Quote
