08-27-2011, 11:19 PM | #1 |
Rear Anti-sway bar worth it on C20?
Hey fellas, I have an 85 C20 Silverado, and it has the front sway bar. Its a camper special.
I was wondering, she has 4 brand new bfgoodrich load rating E tires which I hoped would help cornering (although Idont race the truck lol). Has anyone ever put a rear anti swaybar on their truck and did it help with overall handling and driveability? |
08-27-2011, 11:38 PM | #2 |
Re: Rear Anti-sway bar worth it on C20?
I had a 77 c20 with the deluxe camper package and factory rear sway bar;It worked well with the camper;did not notice any difference when the truck was empty ...the springs on a c20 are fairly stiff when unloaded.
All the one ton dually pickups came standard with a rear sway bar ...I think the target market was campers and with all that weight up high a rear sway bar would help the handling. I always was going to take most of the rear leafs out and put 1/2 ton springs in the front of one of our crewcabs and see how it rode and handled but we never did it....has anyone else tried that. |
08-28-2011, 02:45 AM | #3 |
That's a real nice, clean looking truck! Yes, a rear sway bar will help.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
08-28-2011, 07:29 AM | #4 |
I have put a set of rear 52's from one of my trucks into the front of my crewcab. Gives you a 4" lift thou. I have not driven it thou I am in the build process.
08-28-2011, 09:53 AM | #5 |
I couldnt see a rear sway bar making an overly dramatic difference with hauling what you got behind you in that pic. If you had a heck of alot of weight in the form of a tippy camper I'd say for sure you could benefit from a set. All your weight is gonna be low on your rear end I'd spend the money elsewhere. I guess it would makke a difference in high speed cornering for sure though.
DIGGER 1984 GMC Sierra 1500 LQ4 T56 12B Chopped 2 1/4, Dropped 6/7, Shaved, Yenko Stripes 2004.5 CCSB GMC 2500HD DMAX LLY, 6" Liftmaster, 6 Fox Resi 2.0 325/50/22" Kumho A/T on KMW's LBZ MP, 5"Ex, Bullydog GT 1996 ECSB GMC Sierra 1500 350/4L60E, FL Headers, 2450 Stall, 6" Pro Comp,3" BL, Shock Hoops, , TrXus STS 38's Last edited by slammedLT1; 08-28-2011 at 10:02 AM. |
08-28-2011, 10:05 AM | #6 |
I don't know about the rear swaybar, but I do know that when the bushings on my front swaybar were worn out the truck cornered not very well, so you might check your front bushings just to be sure. I got the blue bushings from the local auto parts store and I think they might have been poly bushings - made a big difference. Mostly I have heard/seen rear swaybars on motorhomes and pickups with truck campers. AIRC, the aftermarket ones are pricey but effective.
08-28-2011, 10:23 AM | #7 | |
My front bushings are in fact worn out. I may look into a new set. Thanks! |
08-28-2011, 02:42 PM | #8 |
The rear sway bar is never present in any of the 1 ton trucks i see in the junkyards in So cal...I'd like to put one in my 1/2 ton to compliment the 1.25" front bar.
08-28-2011, 04:26 PM | #9 |
yep I just had my bar checked and its a 1 1/4" also. I found the bushings at the auto parts store. Gonna put em in later today when it cools down!
08-29-2011, 03:59 AM | #10 |
oh boy. ok here we go. sway bars help stop side to side movement or "roll" so lets say u haul pallets all day.. yes a sway bar would do wonders... that boat is gonna wanna keep the rear solid... so if u haul her more then lets say pallets...id look into the firestone ride rite system. very user friedly and make for for pulling and leveling stability. but yes. a swaybar (anti sway bay) will improve handeling no matter what, empty. full loaded unloaded or resting on the overloads haha. swaybars shold b factory on everythibg however that costs money and peiple like to save it for some reason. so will a performance add on add performance? YES.
