Old 08-27-2011, 11:48 PM   #1
FL71C10
LT-1 swap questions
I had someone offer to sell me a 95 Trans Am with an LT-1 motor in it. I'd like to put it in my 71 truck. Will I need a high hump trans tunnel for the 4L60E transmissions. What about the radiator. Will I need a new one, or can I use my stock one. Any help I can get would be appreciated.
Thanks!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 08-28-2011, 07:05 AM   #2
FL71C10
Re: LT-1 swap questions
No one? I know some of you have done this swap.
Old 08-28-2011, 01:23 PM   #3
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
My brother has a 72 with an LT-1 when it was put in they used the radiator from the Camaro. They also used the electric fans from the Camaro. It looks nice and works great no overheating, even with A/C. The engine mounts were moved to the furthest back position also. I know you must want some pics, I will see if I can get some for you
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 08-28-2011, 02:02 PM   #4
briankk60
briankk60's Avatar
Here is a pic of my 72 LT-1 swap. Its almost done but a few things left to do.
briankk60 is offline   Reply With Quote
Old 08-28-2011, 02:41 PM   #5
chevytruckluver
No need for a high hump tunnel. One other thing you will need to relocate the a/c compressor. The F body location is low on the pass side. It will hit the frame rail if left there, some guys have notched the frame but I would rather find another mount if your truck will have a/c.
Trey
72 Short Step
Old 08-28-2011, 03:19 PM   #6
FL71C10
Looks nice! What AC brackets did you use?
Old 08-28-2011, 03:20 PM   #7
FL71C10
Any suggestions on what AC brackets to use? Roadmaster or Impala maybe?
Old 08-28-2011, 03:22 PM   #8
FL71C10
Thanks for the info. Any pics you can find would be great!
Old 08-28-2011, 06:24 PM   #9
6772owner
Gearhead
6772owner's Avatar
I love my LT1 swap, I used an older 700R4, but did not modify any of the firewall or trans tunnel on my truck. I have the high hump, but the trans is no where near it. I am using the Camaro radiator, fans, radiator hoses, p/s res, etc. Basically everything I could that came out of the donor car.
I believe that you need to use the Corvette accessory bracket to use A/C, the other models you mentioned may work (or be the same) if they put the A/C compressor up high on the Drivers side as in the photo above.
Here is mine....
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 08-28-2011, 07:39 PM   #10
chevytruckluver
Actually Brian is my brother, the pic he posted was right afer he bought the truck, Its even nicer now. It has the vette front brackets.
There is an aftermarket bracket system out there too.
here is a link http://www.oldairproducts.com/catalo..._69000016.html
Trey
72 Short Step
