View Poll Results: Electric or Mechanical Fuel Pump???
Electric Fuel Pump 5 50.00%
Mechanical Fuel Pump 5 50.00%
Voters: 10. You may not vote on this poll
Old 04-09-2003, 05:48 PM   #1
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
Mechanical Or Electric Fuel Pump??
What would you guys recomend and what are the pros and cons of each?? Thanks
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 04-09-2003, 06:42 PM   #2
70c10
67-72 Addict!
70c10's Avatar
I have always heard electrical pros are they push fuel instead of pulling it. This maintains cooler fuel to prevent vapor lock!. The cons would be a little more cost and possible explosion I think if it was hit. I'm not sure about that one though. I plan on doing that switch to my truck. Vapor lock sucks!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-09-2003, 07:36 PM   #3
mikep
Used to have a truck
mikep's Avatar
A good mechainical pump is quiet and will never vapor lock. I highly suggest the Carter mechanical racing pumps. They dont vapor lock and will flow as much as most racing electric.
If your dead set on a electric pump go with the mallory gerotor design. They cost more than the holley but are much more reliable and are extremely quiet compared to the holleys while still surpassing the holley flow rate. Those holley electric fuel pumps are the most god awful obnoxious things in the world next to gear drives .
No truck :-(
mikep is offline   Reply With Quote
Old 04-09-2003, 07:58 PM   #4
rage'nrat638
rage'nrat638's Avatar
magna flow is the best hands down....
rage'nrat638 is offline   Reply With Quote
Old 04-09-2003, 11:03 PM   #5
Mike C
Mike C's Avatar
I'm with Mikep on this one. Get a Carter street/strip pump for about $60. I even adapted mine to my stock GM line. I am going to order a street pump for my '69 Camaro and through the POS Holley electric into the parts bin. At WOT it only flows 1 1/2 psi, glad I never ran the button on it...
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
