![]() Join Date: Jun 2011
1971 cab
It there any thing differant from a 70 4x4 cab to a 71 2wd cab ? Will everything from my 70 fit right in to the 71 ??
![]() Join Date: May 2007
Re: 1971 cab
if the hump doesnt bolt in on the four wheel drive then pretty much yes, gas pedal mounting is about all i can think of
its all about the +6 inches
Re: 1971 cab
the 4x4 will have a bolt in high hump floor for the trans hump. The 2 wheel drive will be a low hump unless it was a big block or a 4 speed. Either swap the bolt on high hump, or cut out the low hump and bolt on the 4x4 high hump.
The 70 will have a throttle rod, and the 71 a cable. You can rig the 70 to work like the 71, but to make it look and fit like a real 71, you'll have some cutting and welding to do. The 71 will have a raised mounting pad for the rear view mirror, the 70 won't have the raised pad.... but who cares. |
#4 | |
![]() Join Date: Feb 2001
Re: 1971 cab
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
